IPB
Welcome Guest ( Log In | Register )
Log In or Register to Remove This Ad!
Check out Retrax's new Silver Pickup Bed Cover!
2 Pages V   1 2 >
Reply to this topicStart new topic
> 5.3 Coolant Loss, 2000 chevy silverado
larry111069
post Dec 17 2007, 01:22 PM
Post #1
GM-TC Enthusiast
Group: Member
2000 silverado
I have a 2000 silverado 1500 5.3 .I have serious coolant loss ,and slight miss in engine.I'm 100% sure its goin out the tail pipe.Is there any common issues here etc.weak head bolts,bad gaskets ,bad head castings?just want to know before I tear it down.It still runs decent but not like it should .This thing has been serviced,taken care of properly.
This post has been edited by larry111069: Dec 17 2007, 01:33 PM
Go to the top of the page
+Quote Post
C & A s Dad
post Dec 17 2007, 02:11 PM
Post #2
Elite Enthusiast
Group: Member
2002 GMC
Yukon XL
Larry, I am not a Tech but am in the Auto Parts Industry. I have read a few post of head gasket issues but from what I can tell this is not a common issue in the 5.3. I would be sure it is not the WP gasket before tearing into it. The WP gasket has been a big issue and the leak is almost impossible to see.
'02 Yukon XL 5.3 4.10 Gear
True Flow CAI, Red Taylor 8.2 PowerVolt Wires, Amsoil Fluids front to rear, RA300 Filter Mag, AirLift Air Springs, PML Finned Alum. High Capacity Diff. Cover, Putnam XDR Class V Receiver, Aeroforce Interceptor Scan Gauge, Hypertech Max Energy Tuner
'71 Chevrolet Custom Deluxe SWB
350/4bbl, PS, AT, AC 100% Original, Even the Paint
100% American Iron
May the products and/or services that you provide not become incorrectly perceived as inferior to similar products and/or services offered by foreign companies as has happened with the Automotive Manufacturing Industry.
Be American, Buy American !!!
+Quote Post
TahoeMike
post Dec 17 2007, 10:09 PM
Post #3
Group: Member
Chevrolet
Silverado Z71
If it has just started, get it fixed quick! My 2000 Silverado used coolant slowly for about 2 years, half a gallon every 3000 miles or so. Then it started getting worse so I decided to replace the head gaskets. Well, when I took the valve covers off, their was a ton of sludge in the tops of the heads and the drivers side with the PVC valve had a bunch of butterscotch colored junk in it also. I cleaned out the heads as best as possible and put it all back together. When I went to change the oil after replacing gaskets I pulled the drain plug out and nothing came out! Ran a screwdriver up in the hole and had to clean a lot of sludge out to get the oil to drain. Not good! I decided now was a good time to change the engine. Found one with 50,000 on it for $900 complete with intake, injectors and coils. When I got the old motor out I pulled the oil pan off and there was an inch or more of sludge in it. Nasty stuff. I take care of my truck. It had 116K miles on it at this time and I ran Castrol GTX until about 85,000 miles and only Mobile one since then. I'm guessing the sludge was from coolant mixing with the oil for quite a long time. It was going to be only a matter of time before the oil pump pickup got that sludge in it and seized up.
2008 Silverado 1500 Crew Cab Z71 4X4
Summit White
+Quote Post
larry111069
post Dec 17 2007, 11:23 PM
Post #4
GM-TC Enthusiast
Group: Member
2000 silverado
QUOTE (C & A s Dad @ Dec 17 2007, 02:11 PM) *
Thanx for info but im gettin steam out exaust .Changed coolant and have noticable smell at exaust.
+Quote Post
larry111069
post Dec 17 2007, 11:27 PM
Post #5
GM-TC Enthusiast
Group: Member
2000 silverado
QUOTE (TahoeMike @ Dec 17 2007, 10:09 PM) *
Man THANKYOU! finaly the real heads up on whats goin on.Were you able to pinpoint the leak being the gaskets?I'm tearing mine down asap.
+Quote Post
TahoeMike
post Dec 19 2007, 09:52 PM
Post #6
Group: Member
Chevrolet
Silverado Z71
I don't think it was the gaskets because it was still using coolant for the short time I drove it after changing them. I think there was a crack in one of the heads but haven't checked them yet. I don't think you can magnaflux aluminum heads, probable have to be x-rayed. I know there is also a Tech Service Bulleting about some heads cracking but the TSB I saw covered 01-03 I think. I'm thinking it may have cracked when I put SeaFoam in it through the power brake vacuum line. Maybe I put too much in at one time and got a mild case of hydro-lock that cracked it.
Summit White
+Quote Post
Kania2k1
post Jan 11 2008, 02:56 PM
Post #7
GM-TC Resident Jack@ss
Group: Member
2001 Chevrolet
Silverado Z-71
I actually just had my water pump changed yesterday. The SES light was coming on every once in a while, and I finally had someone other than the dealer do a code read. THere was a small leak at the waterpump, but nothing to the effect that I would have to add coolant every 3k miles. I've also heard that this is an ongoing issue with some of the trucks in our model year range. Could be it. Have you thought about adding the die to the coolant and trying to trace the leak? Or does it seem to be only an internal leak?
2001 Ext. Cab. 4dr Z-71 Silverado Black trim painted to match. Escalade passenger door handles, billet grill & bowtie, Flowmaster Dual out single side exhaust, Sportsmaster tonneau, Hi-4 Headlight kit, Alpine IVA-D100 in-dash DVD player/monitor, Alpine Type-R 6 1/2" Front Components, Westers 93 tune, K&N 77 series air filter, Northern Tool under rail tool box
http://community.webshots.com/user/kania2k1
!!GO BIG ORANGE!! !!GO BOILERS!! Shift_ignorance
+Quote Post
TahoeMike
post Jan 11 2008, 06:13 PM
Post #8
Group: Member
Chevrolet
Silverado Z71
Pretty sure mine was only an internal leak. Had a dealership check it out once and found no evidence anywhere on the outside either.
Summit White
+Quote Post
Geno
post Jan 15 2008, 07:30 PM
Post #9
GM-TC Newbie
Group: Member
2005 GMC
Sierra
QUOTE (TahoeMike @ Jan 11 2008, 03:13 PM) *
Bulletin No.: 06-06-01-019B
Date: June 12, 2007
INFORMATION
Subject:
Information on Gradual Coolant Loss Over Time With No Evidence of Leak Found.
Some vehicles may experience a gradual coolant loss over time. A very low percentage of cylinder head(s) manufactured with an embossed Castech logo may develop a porosity crack in a very specific area.
+Quote Post
PunchT37
post Jan 15 2008, 10:06 PM
Post #10
GM-TC Enthusiast
Group: Member
Chevrolet
2000 Silverado
And you`ll have to pull the rocker arm bridge to see the logo. The cracks are usually around the center headbolt area under the v/c where the oil drains back. Most heads iv`e seen do this are the "706" casting and not the "862".
+Quote Post
svensk
post Jan 15 2008, 11:33 PM
Post #11
Toyotas lead to sodomy
Group: Member
2000 GMC
1500 SLE 4x4 5.3
Oh great... Well I'm not pulling that crap off just to see if I have those heads. I'll just continue to monitor my levels.
+Quote Post
Cadha13
post Jan 18 2008, 12:06 AM
Post #12
GM-TC Enthusiast
Group: Member
2005 GMC
Sierra 1500
Name: David H. Aragon
Metal porosity is a big problem especially with aluminum. Sludge build up is a sign of a coolant passage porosity and need to have those heads changed pronto. I have never seen any vehicle use more than a pint of coolant in normal service in any of the vehicles I have driven in a duration of a year. But I haven't driven a car with aluminum heads just cast iron ones. That includes a 1972 Chev pickup (350 V8), 86 Caprice (305), 1993 Chev Pickup (4.3L), 2000 Monte Carlo and Impala (3.8L and 3.4L), 78 GMC truck (250 L6 and 305 V8 now) and my 2005 GMC (4.3L).
My 2005 GMC 1500 Sierra 4.3L V6 5spd. manual, elec cool fans, Amsoil(5W-30, 25K oil change), cloth seats with rubber floor. My perfect truck. Utilitarian and fun to drive. 12400@ my 21st Bday! 01/06 Drum Brakes and a distrubutor!! Hows that for old! http://s221.photobucket.com/albums/dd3/cadha21/Hey this what I like Also.
+Quote Post
TahoeMike
post Jan 19 2008, 12:30 PM
Post #13
Group: Member
Chevrolet
Silverado Z71
QUOTE (Geno @ Jan 15 2008, 07:30 PM) *
Date: June 12, 2007
INFORMATION
Subject:
I thought that bulletin was for 01 and up, does it cover 00's also?
Summit White
+Quote Post
tmicklet
post Aug 13 2008, 09:05 PM
Post #14
GM-TC Enthusiast
Group: Member
2004 Sierra 1500 Crew
Hi guys, how many of you have had problems with cracked heads? I have the 706 casting heads on my 04 gm crewcab. Its using coolant, sometimes smoking on cold start, valve lifter tick on cold start, cream coloured sludge on underside of valve covers. Sound like a cracked head to you guys?? Any info or ideas would be great. Thanks , cheers
+Quote Post
northern rider
post Aug 29 2008, 09:37 PM
Post #15
GM-TC Enthusiast
Group: Member
1999 GMC
Sierra 1500 4x4
QUOTE (tmicklet @ Aug 13 2008, 10:05 PM) *
I have a 1999 GMC 4.8l 150,000 miles and have had the same symptoms so ended up changing the head gaskets. Have put about 150 miles on since and so far it has not used anymore coolant and the condensation on oil filler cap has pretty much disapeared so it looks like that may have fixed it.
The only thing I found real obvious is the 5, 8mm bolts along the top of the heads had lost torque, they supposed to be 22 ft lbs, so I would be tempted to pull the intake manifold and check the the bolts mentioned above before changing the head gaskets.
This post has been edited by northern rider: Aug 29 2008, 09:52 PM
+Quote Post
2 Pages V   1 2 >
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 9th February 2010 - 04:31 AM
Sponsors
Our Friends
AutoInsane.com
GM-Hybrids.com
SilveradoSS.com
TrailBlazerSS.com
