IPB
Welcome Guest ( Log In | Register )
Log In or Register to Remove This Ad!
GM-Trucks.com is proud to welcome Schram Auto Parts as a supporting vendor!
Reply to this topicStart new topic
> Replacing Balljoints On 04 1500 Z71
lowcountry
post Feb 18 2010, 02:10 PM
Post #1
GM-TC Newbie
Group: Member
2004 Chevrolet
1500
It started with the occasional "thunk" when backing out of the driveway and then it proceeded to get worse whenever turning. I decided to replace both joints since I was going to have my truck tore down this far anyways. Moog balljoints with lifetime warranty were $150. I used the tool loaner program at O'Reily's and got the ball joint press and pickle fork from them. The other special tool I had to use was a large axle nut socket that I got a while back to change the hub bearing. According to the manual, you are supposed to take off the control arms and take them to a shop to have them pressed out and new ones pressed in. With a ball joint press, you can do it yourself and save a bunch of money. Leaving the shock connected allowed me to not have to unload the torsion bar. I did keep the jack underneath the lower control arm just in case. I am going to get new tires soon so it will be getting an alignment then. If I already had good tires on it, the first stop would be for an alignment. I searched everywhere for guidance on how to do this. Hopefully this will help anyone else interested in doing this.
Start with getting the truck jacked up, supported, and tire off.
Remove the brake caliper mount and tie the caliper out of the way.
Remove the anti-sway bar.
Remove the dust cap and axle nut.
Now you can remove the halfshaft after unbolting it from the differential flange. Then it can be removed through the low control arm. I choose to index the halfshaft. Probably wasn't necessary but it can't hurt.
Halfshaft out of the way.
Using pickle fork to separate the balljoint from the steering knuckle.
Now for the bottom. I had to beat this one like it owed me money. You can also see I disconnected the tie rod.
Once I got the bottom joint separated. I removed the steering knuckle. I ended up having to loosen the bearing to get the ABS sensor out. So I just completely dissembled it which wasn't necessary. I carried away with the impact wrench I guess.
Top joint came out with no problem.
With the bottom joint, I had to knock 4 crimps back in. Here I have it half way out.
Pressing the new one in.
Got both joints back in and ready to start reassembling everything.
If anyone has any questions, feel free to ask.
This post has been edited by lowcountry: Feb 18 2010, 02:11 PM
Go to the top of the page
+Quote Post
azchevy99
post Apr 28 2010, 10:39 AM
Post #2
GM-TC Enthusiast
Group: Member
1999 Chevrolet
Silverado
Nice write up man. I was planning on replacing my lowers this weekend and was going to remove the whole control arm. What did you use to get the old ball ends out though?
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 9th September 2010 - 06:24 AM
Sponsors
Our Friends
AutoInsane.com
GM-Hybrids.com
SilveradoSS.com
TrailBlazerSS.com
