96 vortec,
Sorry to hear about your loss but your loss does yield some very nice donor parts to play with. I haven’t done a swap such as this on any of my vehicles yet although I work for a commercial truck manufacturer and have worked with many of my fleet customers on swapping in L31 engines into older Chevrolet and GMC P-chassis stepvans (breadtrucks, Frito-Lay trucks, UPS trucks, etc) that originally had 250 and 292 I6 engines or carbureted small blocks. I am also getting ready to fuel inject a 454HO that I just bolted into my 78 K10.
As far as swapping your L31 350 into a pre-fuel injected truck is also proportioned to your skill as Instrument 39 mentioned above. If you pay a shop to do this forget it…a project like this is only feasible if you can perform the labor yourself.
Obviously your L31 will be a direct bolt in to any older Sub but you will have a few choices when it comes to the engine management system. You can either painstakingly surgically remove all the uncessicary wires from the Z71 wiring harness that are not needed to run the engine and 4L60E slushbox trans...which takes a lot of skill and a good understanding of OBDII and basic electronics then create your own wiring harness. In my opinion this is the worst method….but possible if your good at that kind of stuff.
You could also check the wiring harness offerings available in the aftermarket such as Painless Wiring or Howell EFI. These are good but you will still have to run OBDII with all of the aftermarket wiring harness kits that I am aware of which means you are screwed with out an expensive scan tool to check for fault codes just as you are today if your Check Engine Light came on your Z71. Trust me…you will have plenty of fault codes that will have to be taken car of once you start messing with that many wires as something is bound to go wrong. Something always goes wrong. GM has also created a wiring harness kit to retrofit L31 engines into older P-chassis trucks that I spoke about above but this is not a free flow part number available through any dealer and only sold directly to National Fleet Account customers so forget the GM kit. You would think GM Performance Parts would snake that kit number right up for the street rod crowd but nope.
Again, my opinion only, the best method to retrofit newer powertrains into older vehicles to go with GM marine wiring harness and engine controller from a boat that runs an L31. You can purchase these harnesses and controller from most Marine dealers that sell boats with GM Powertrain engines. You will have to do some fandangling to these harnesses and rig up a Vehicle Speed Sensor signal which can be done with aftermarket parts but that is very minimal compared to the other options. You will also have to change you accelerator pedal to a very late model (2003) electronic pedal assembly as no throttle cable can be used. This also means you will have to change the throttle body on the engine to the electronic marine version as well since L31 small blocks were never available in automotive form with a Throttle Actuation Control module. The best part is you can run these on OBDI like an early 80’s though 1995 GM vehicle and still have port fuel injection for most years of marine applications without smog retrictioned pony robbing fuel and timing calibrations.
That is the route I am going with my project. Like I say, I have a 454HO that is set up like a late 90’s L29 454 but currently with a carburetor. YUK! The good news is I just came across a complete 1999 GM medium duty truck LP4 454 sequential port fuel injected intake for a very good price. The other good news is the LP4 454 basically used all PCM and wiring as a marine applications with 1996 though 1999 big blocks so that is the route I am planning to go. One of my counterparts that works in GM Powertrain side of the business teaching me on this late model EFI swappage using all readilly available GM part bin components to help our fleet customers that are repowering older trucks. We’ll see how well all this recently acquired education works once I apply this entire BS into a 78 K10 apposed to a 1980’s bread truck.
Here is my new big block awaiting EFI. As far as the transmission and transfercase you will have to use an early NP241 with a right side front output shaft as you 96 Z71 has a left output shaft. The trans will bolt right in except for some minor shift linkage fangling but you will have to purchase a stand-alone controller from someone like TCI to run the 4L60E. Boats don’t use those trannies
Sorry for the long post…I just find late model engine swaps intriguing.
