IPB
Welcome Guest ( Log In | Register )
Log In or Register to Remove This Ad!
GM-Trucks.com is proud to welcome Schram Auto Parts as a supporting vendor!
Reply to this topicStart new topic
> 2001 jimmy obdII code p410, 2001 jimmy obdII code p410
GMJIMMY61
post Feb 7 2005, 12:08 PM
Post #1
GM-TC Newbie
Group: Newbie
GMC
Jimmy
Could someone please confirm if this is MAF related and any cures if possible? Thanks in advance. GM
Go to the top of the page
+Quote Post
GMCTech
post Feb 10 2005, 05:29 AM
Post #2
Senior Enthusiast
Group: Newbie
GMC
GMC only!!
P0410 is a fault of the A.I.R. pump and nothing else. I have never seen any other sensor or fault cause this code. (And I have diagnosed MANY P0410 codes.)
Here's the story on the P0410:
The AIR pump adds air to the exhaust stream to lower emissions. It does this by taking in outside air and pumping it through two one-way check valves into each bank of the exhaust.
About 90% of the time that this code is set, the one-way check valves have worn out or failed and allow water (which occurs naturally in the exhaust) back into the pump. In any cold climate, especially in the northeast with higher humidity, this water may be more excessive. The water partially fills the AIR pump, it can then freeze. When the PCM commands the pump on, if the pump is frozen it cannot turn, thus overloading the circuit and "popping" the fuse.
As far as the location of the fuse, it is in the right front fender well beside the battery, and in front of the horn there.
Sometimes replacing the fuse will fix all your problems and you are all set until next winter when it all happens again.
Also, sometimes water is allowed to enter the pump through the intake side of the system (just a 5/8" hose behind the fan shroud) and ruins the system that way. -I'll talk about that in a moment.
GM says that when this system failure occurs due to water intrusion, the pump MUST be replaced. I have had decent luck just blowing the pump out with direct power provided by a test bettery out of the vehicle, and saving the customer some $$$ :thumbsup:
GM has also released a remote air intake kit that includes a longer 5/8" hose, a control solenoid, and a one-way check valve to eliminate most possibility of water intrusion.
Like I said before, sometimes just blowing out the motor and replacing the fuse will solve your problem. BUT, to truly repair the problem correctly the AIR pump, the fuse, and the exhaust check valves must be replaced, and the remote air intake kit must be installed. banghead.gif $$$
I have much experience with this AIR system. Here in the northeast it is a BIG problem, and we have replaced at least 100 AIR pumps in the last 2 years or so.
If your vehicle is still under warranty, then you are lucky. --> The exhaust check valves usually wear out after 3-4 years thus, putting most vehicles out of warranty coverage. :sly:
Hope this explains the infamous (at least here in the northeast) P0410.
+Quote Post
belair56
post Jun 21 2006, 05:49 PM
Post #3
GM-TC Newbie
Group: Newbie
1999 GMC
Tahoe
QUOTE (GMCTech @ Feb 10 2005, 03:29 AM)
Can you help me. I have the same problem with my 1999 Chvey Tahoe. I got the code P0410 Secondary Air Injection System Malfunction when I got the truck smogged and it failed on that code and the check engine light. I went to the Chevrolet Dealer Parts dept and tried to order the injection valve, because they recommended that it might be the valve that causing that code to appear, but when they punch in my Vin and found out that i don't even have that air pump and the hose that's connected to the exhaust and come out and check it they did not see it. So how can I fix this problem. Thanks Jeff
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 3rd September 2010 - 11:34 AM
Sponsors
Our Friends
AutoInsane.com
GM-Hybrids.com
SilveradoSS.com
TrailBlazerSS.com
