- 0
Bypassing Ignition Wiring
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 22 Members, 0 Anonymous, 1,787 Guests (See full list)
Question
heygibb
I'm working through bugs on my recently acquired 89 sierra 4wd. This past week, the starter wouldn't turn over. After ruling out the battery, I removed the starter and bench tested it...all ok. I re-installed it but it still would not turn over. I turned the ignition key on and then shorted the two terminals on the starter and it started right up.
I decided to replace both the ignition key cylinder and ignition switch, hoping that was the problem. Unfortunately, I still have the same "click" when the key is turned.
I've decided to wire the two terminals from the solenoid to a dash mounted switch and bypass the normal wiring. Is there something else I should check out or replace before going this route? It's a hunting/fishing truck, so adding the switch doesn't bother me. It just seems to be the easiest way to overcome the lack of power getting to the starter.
grassy ass, amigos!
0 answers to this question
