Showing results for tags 'how to replace sierra wheel hub'.
Wheel Bearing Replacement. Learn how to diagnose and replace the wheel bearing hub assembly on almost any truck or car. This is a 2004 Chevy Silverado, GMC Sierra but the process will be very similar for replacing any wheel bearing hub assembly with an axle running through it. I was able to purchase a new hub assembly from AutoZone for $120. Duralast Wheel Bearing/Hub Assembly-Frnt. We will provide a review of the wheel hub assembly after testing it for some time before recommending you to purchase it. Other wheel hub assembly companies: Moog, NAPA, Driveworks, Timken. Here is the Wheel Hub Assembly that I used: https://www.autozone.com/suspension-s... Similar Wheel hub assembly products available on RockAuto: https://www.rockauto.com/en/catalog/c... ****************************************** Required Tools • 15mm Wrench • 18mm Socket • 22mm Socket • 35mm Socket • Lug Wrench • A Piece of Pipe (for leverage) • Ratchet • Torque Wrench • Hammer • Chisel • Jack Stands
