Truck is staying at 205 degrees but fan will not come on. Just changed water pump because it was leaking and thermostat tested the three relays marked cooling fans and fuses. The gauge inside cab appears to work. The fans will not come on and the lower radiator hose stays cold while the top one gets scorching hot. Please help
