Showing results for tags 'service rear vision camera'.
I have seen some threads about "Service Rear Vision Camera" appearing on the MyLink screen, but haven't seen any fixes. I have a 2014 Silverado 1500 High Country, 70,000 miles, "Service Rear Vision Camera" has appeared on my 8" screen. The distance marker lines still appear. Just do not get a picture from the camera and has "Service Rear Vision Camera". I have inspected and cleaned the wiring and plug for the camera under the bed. Inspected the camera attached to the handle from the inside. Nothing appears damaged or worn. What do I need to service to correct this? How do I reset the rear vision camera with the MyLink Equipment? Is there a fuse or relay that may be causing the problem with the connection? Do I need to replace the cable? Can installing LED brake/turn/park lights cause this issue? Can anyone help? Thanks, Jerry
