solarjustin
Replacing The Gear Oil
What brand gear goil?
51 members have voted
  1. 1. What brand gear oil do you like? And Why?
    • Amsoil
      13
    • Mobil 1
      16
    • Red Line
    • Royal Purple
      4
    • Other
I'm going to replace the gear oil on my 04 with 60k miles. It has never been done before on this truck. Right now I'm leaning towards the Amsoil but wanted to see what you are all using and how you like it.
Thanks
Share this post
Link to post
Share this post
Link to post
I've used both Mobil 1 synthetic gear oil and Lucas Oil gear oil in both front and rear differentials.
Share this post
Link to post
Amsoil would be my first choice and Mobil 1 second. Both are very good and very easy to find at local stores, but Amsoil has proven to be a winner as far as I'm concerned. I started running it in my Harley after using their Screamin' Eagle full synthetic for years. Now the motor runs 20 degrees cooler and much smoother. That says alot for me!
Share this post
Link to post
It'll take 2 qts. for sure and probably a little of a 3rd qt. I know on my '04 (3.73), 2 put it right at the correct level. YMMV though. If you end buying something local and you don't need the 3rd qt. you can always return it.
Share this post
Link to post
I used to run exclusively Mobil 1; this time around though I put Royal Purple in and I honestly think it does a better job than my M1 ever did.
Share this post
Link to post
I've never had any rear axle problems (or front on 4wd) using anything from Sta-Lube to Mobil 1. Frankly, I can't tell the difference. My El Camino had half a million miles on the stock rear axle and mostly Sta-Lube in it that was only changed a couple times and it had engines in excess of 400 hp in front of it. Sta-Lube has to be the cheapest stuff money can buy. I run Mobil 1 now, because it's in the stores.
Share this post
Link to post
Now days I don't think it matters as much. I have good luck with Amsoil just like others have had good luck with other brands. I did check my mileage and driving before I changed all of my fluids to Amsoil, then switched and I still 13 months later have not noticed even a 1/2 mpg increase, thats what I was hoping for. The truck will make it to 300k on standard oil
Share this post
Link to post
My experience with the El Camino was from about 1980 to 1998. Gear metallurgy in GM products hasn't changed much if any since then. Even if it did, what more could we ask for? The rear axle will probably outlast the truck, if it isn't damaged from abuse.
Share this post
Link to post
+1 Amsoil first then Mobil1 for me.
Share this post
Link to post
Here is a list of Capacities
2004 CHEVROLET TRUCKS 5.3L 8-cyl Engine Code [T]
CAPACITIES
Engine, with filter..........6.0 quarts[1]
Cooling System, W/ FR & RR AC Initial Fill..........16.0 quarts
Cooling System, W/ Front AC Initial Fill..........14.0 quarts
Automatic Transmission, 4L60-E Initial Fill..........5.0 quarts
Automatic Transmission, Total Fill
4 speed 4L60-E..........11.0 quarts
Differential, with 8.25 ring gear Front..........3.0 pints
Differential, with 9.25 ring gear Front..........3.2 pints
Differential, with 10.50 ring gear Rear..........5.5 pints
Differential, with 11.50 ring gear Rear..........7.6 pints
Differential, with 8.60 ring gear Rear..........4.2 pints
Differential, with 9.50 ring gear Rear..........5.5 pints
Transfer Case,NP8..........4.0 pints
Transfer Case,NR3/NR4..........3.0 pints
Transfer Case,NVG 246-NP8..........4.0 pints
Transfer Case,NVG 261-NP2..........4.0 pints
Transfer Case,NVG 263-NP1..........4.0 pints
Share this post
Link to post
How do you tell which gearing you have?
CAPACITIES
Share this post
Link to post
Mobil-1 for me, never had good luck with Amsoil engine oil (consumption issues in truck, quad, sled) maybe not an apples to apples comparison but to be honest Amsoil makes me a little nervous :lol:
Share this post
Link to post
