Heater Hose Quick Disconnect
  • Please log in to reply
4 replies to this topic
#1 BDK
BDK
  • Member
  • 31 posts
Posted 07 September 2009 - 10:43 AM
I have a 2001 Silverado, 5.3L and after studying the heater core quick disconnects for the heater hoses, I found that the black disconnect has a plastic collar over the area where the hose itself enters the disconnect fitting. This black plastic collar (hole on either side and split) simply spins around on the hose and doesn't seem to do anything. Is this thing supposed to be a clamp of some sort? The other side of the core (white side) has a good old fashioned clamp in this area.
My question is this....how does the hose stay attached to the factory plastic disconnect? Is it fused on from the inside? Trying to figure out as much as I can about this set up before I remove the hoses for routine maintenance.
By the way....is 8 years old and 60,000 miles too soon for replacement?
#2 txab
txab
    Your worst fWONking nightmare
  • Moderator
  • 6,747 posts
  • Gender:Male
  • Drives:2004 GMC Sierra
Posted 07 September 2009 - 12:03 PM
Are you sure the the plastic ring twists, or the hose and connector twisting on the HC pipe. You can remove the clamp and cut the hose on the white one. You can remove the other one with a tool available from the parts store.
I'd be prepared to replace one or both with new ones. Once removed they don't always fit and seal so good again.
Attached File  gatesconnectors.jpg   10.18K   50 downloads
Posted Image
"When the people find they can vote themselves money, that will herald the end of the republic."
-- Benjamin Franklin
Posted ImagePosted ImagePosted Image
#3 BDK
BDK
  • Member
  • 31 posts
Posted 07 September 2009 - 04:03 PM
No, the plastic collar just spins on the hose freely and the hose stays stationary...I can just slide it down the hose....that's what's throwing me...and worrying me that the hose isn't ready to blow off the connector.
#4 BDK
BDK
  • Member
  • 31 posts
Posted 07 September 2009 - 05:28 PM
As a follow up...I found from a neighbor's 2001 that this is indeed a clamp. That round black plastic thing is a hose clamp and I was just real lucky the hose didn't blow off the fitting..
There's a hose clamp on there now and all is well.
#5 alwcurlz
alwcurlz
    "Opinions vary widely, not wildly"
  • Member
  • 761 posts
  • Gender:Male
Posted 07 September 2009 - 11:38 PM
Mine broke when I barely pulled on it to remove it. I then had to cut off the rest of the connector and slid the hose over the aluminum tube/pipe from the heater core. I would suggest doing away with that assembly line connector they used as it does deteriorate and break off like mine did. Once you do get the plastic parts off the tube and out of the inside the hose, the rest is pretty easy, specially with some lube on the hose first to ease sliding it back on the tube from the heater core.
:rollin:
- God's Country -
People fear what they don't understand and hate what they can't conquer:
Matt 10:28
"Those who would sacrifice freedom for security deserve neither" : Benjamin Franklin
"It is better to be hated for telling the truth, than loved for telling a lie."
1999 Silverado LS Z71, 148,000+miles, orig 5.3 V8 with Mobil1 blood, orig 4L60E Transmission, Push-button 4WD, 3.73 G80,
Completely stock making 16-17MPG city streets, 20-21MPG HWY
Posted Image
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Advertise Here
