Help- Check Engine Light Flashing Randomly!
  • Please log in to reply
26 replies to this topic
#1 03 GMC 2500HD
03 GMC 2500HD
  • Member
  • 67 posts
  • Gender:Male
Posted 07 September 2009 - 06:55 PM
Well, for the last month or so, my check engine light has been randomly (anywhere from 3 to 35 flashes at a "time") flashing when driving at highway speeds (only at 60+ MPH), and at 50MPH when towing a heavy load (5K+).
I took the truck to advance auto today to get it scanned- it pulled a P0300 code- random/multiple cylinder misfire.
The truck runs 100% (near as I can tell) fine, runs around town no problem (no light so far), and on the highway fine, just the light is flashing at times.
It idles smooth- same as it always has...
Any ideas on the culprit? The truck has 72,000 miles on it, maintained well, original plugs/wires etc.
Thoughts?
My Truck:
2003 GMC Sierra 2500HD 4X4 SLE- 6.0L V8, Auto Trans, Reg Cab, Long Bed!
#2 txab
txab
    Your worst fWONking nightmare
  • Moderator
  • 6,759 posts
  • Gender:Male
  • Drives:2004 GMC Sierra
Posted 07 September 2009 - 07:14 PM
Here's some info:
http://www.random-misfire.com/
Posted Image
"When the people find they can vote themselves money, that will herald the end of the republic."
-- Benjamin Franklin
Posted ImagePosted ImagePosted Image
#3 03 GMC 2500HD
03 GMC 2500HD
  • Member
  • 67 posts
  • Gender:Male
Posted 07 September 2009 - 08:36 PM
Okay, thanks.
Does anyone know what the GM emissions warranty covers- and for how long? I bought my truck used in '07 with 40,000 on it, now has 72,000 on it- anyone?
Back to the misfire- anyone think it could be that the truck needs to "re-learn" the crank position sensor? Symptoms?
The thing that puzzles me is that my truck only does it at highway speeds, and it's very random???
My Truck:
#4 hockeypro1411
hockeypro1411
    Senior Enthusiast
  • Member
  • 1,621 posts
  • Gender:Male
Posted 08 September 2009 - 08:53 AM
That makes two of us. I'm tempted to do the electrical tape mod.
Posted Image
#5 txab
txab
  • Moderator
  • 6,759 posts
  • Gender:Male
Posted 08 September 2009 - 09:30 AM
You still haven't been able to figure out what is causing your problem? What's the tape mod involve?
Posted Image
#6 03 GMC 2500HD
03 GMC 2500HD
  • Member
  • 67 posts
  • Gender:Male
Posted 08 September 2009 - 01:48 PM
Well, my truck's at the dealer- hopefully they'll have a diagnosis for me by tomorrow- we shall see...
My Truck:
#7 hockeypro1411
hockeypro1411
    Senior Enthusiast
  • Member
  • 1,621 posts
  • Gender:Male
Posted 08 September 2009 - 08:06 PM
No I still have no idea what's causing it. This thread describes it better than mine did.
Lol you've never heard of the electrical tape mod? You cut a square of electrical tape and stick it over the check engine light. This way you'll never know if it's on.
Posted Image
#8 txab
txab
  • Moderator
  • 6,759 posts
  • Gender:Male
Posted 08 September 2009 - 10:00 PM
:rollin: Yeah I've heard of that one. Just a little slow on the uptake today. :thumbs:
Posted Image
#9 03 GMC 2500HD
03 GMC 2500HD
  • Member
  • 67 posts
  • Gender:Male
Posted 09 September 2009 - 07:38 AM
I've been reading, found that other guys with the same symptoms had a bad ECM ground- anyone think this might be it? It's at the dealer right now, so I'm waiting to hear back later from them on what they think the problem is...$$$$$.
My Truck:
#10 hockeypro1411
hockeypro1411
    Senior Enthusiast
  • Member
  • 1,621 posts
  • Gender:Male
Posted 09 September 2009 - 10:11 PM
I've been reading, found that other guys with the same symptoms had a bad ECM ground- anyone think this might be it? It's at the dealer right now, so I'm waiting to hear back later from them on what they think the problem is...$$$.
I can't wait to hear what they say. Mine just tells me that it needs new plugs n wires. Apparently me telling him that I replaced them a week ago wasn't doin' it for him.
Posted Image
#11 03 GMC 2500HD
03 GMC 2500HD
  • Member
  • 67 posts
  • Gender:Male
Posted 10 September 2009 - 09:43 AM
Well, GM called me up yesterday- they said that they pulled the code P0300 (duh- I pulled the same thing), and the only way to correct teh problem was to start replacing parts hoping to get it fixed, costing me an indefinite amount of money and time. So, I took the truck out of their hands, and will run it as is until I can get it home in a month or so to have a buddy of mine look at it. The weird thing is, it only comes on with teh RPM's higher than 2K or so, and I can stomp on it and it still runs fine???? I'm at a loss...
Hockeypro- how many miles have you put on yours with the light flashing?
My Truck:
#12 txab
txab
  • Moderator
  • 6,759 posts
  • Gender:Male
Posted 10 September 2009 - 01:30 PM
I thought I posted yesterday about some info I found concerning aftermarket alarms. Maybe I didn't. :lol:
Anyway, found it so I thought I'd throw it out there for those it might affect.
Info - Misfire DTCs P0300, P1380, P1381 and Catalytic Converter Damage Due to Installation of Alarm Systems #02-06-05-004A - (Jan 9, 2004)
2004 and Prior GM Passenger Cars and Light Duty Trucks
2003-2004 HUMMER H2
2004 and Prior Isuzu Light Duty Trucks
This bulletin is being revised to add the 2004 model year and include specific DTCs in the title line. Please discard Corporate Bulletin Number 02-06-05-004 (Section 06 - Engine/Propulsion System).
General Motors Engineering, in an effort to determine the root cause of catalytic converter damage, has determined that aftermarket alarm systems incorrectly installed in vehicles have the potential to cause misfire codes and damage to the converter. These alarm systems use a circuit interrupt which utilizes the ignition circuit on the vehicles.
These alarm systems utilize mechanical relays and normal vehicle movement can trigger these relays to engage and disengage the ignition circuit while the vehicle is in motion. These disruptions of the ignition circuit, which occur in milliseconds, may cause more fuel to be commanded. Over time, this dumping of fuel on and off again can cause misfire codes and ultimately damage the converter assembly.
Important
Engineering could not identify any alarms that utilize solid state circuitry that would eliminate this concern. Because of this, it has been determined that all alarm systems must be routed through the starter circuit in order to avoid this condition.
Dealers must be aware of this issue and take note of the wiring on vehicles with alarm systems that come in for repair, particularly for catalytic converter damage that seem to have no known root cause.
Posted Image
#13 hockeypro1411
hockeypro1411
    Senior Enthusiast
  • Member
  • 1,621 posts
  • Gender:Male
Posted 12 September 2009 - 12:54 PM
Probably around 5,000. I can't feel a misfire when it flashes. From what you describe, we've both got an identical problem.
Posted Image
#14 brims
brims
    Senior Enthusiast
  • Member
  • 1,605 posts
  • Gender:Male
Posted 12 September 2009 - 02:36 PM
Tell them to do that, but you're not paying for anything that doesn't directly fix it. I know it won't work, but hey. That's crap for them to just throw your money at it. They are the technicians they should be able to know what the most likely cause is and test for that.
Posted Image
2008 Chevrolet Silverado 1500 Extended Cab Standard Box, 2LT, 4x2, 5.3L FlexFuel, 3.73 G80, Graystone Metallic, General Grabber HTS 245/70R17
Mods: Line-X over the rail, WeatherGuard Crossbox, Optima Red Top, MagHytec Differential Cover, Rough Country 2" leveling kit, Corvette Servo, AEM Brute Force Intake, Black Bear tune, Hayden 679 aux trans cooler, Hawk pads, Bilstein shocks, Dual Aeroforce Interceptors, Extang Snapless Full Tilt Tool Box Tonneau
Future mods: 2 low/6 high
Possible mods: rear sway bar, blacked out front and rear bumpers
#15 coloradoSkiCountry
coloradoSkiCountry
    Senior Enthusiast
  • Banned
  • 2,138 posts
  • Gender:Male
Posted 21 September 2009 - 01:13 PM
FYI a flashing Check Engine light means get the thing pulled over and shut off right away. Steady CEL is not as severe.
Posted Image
GM- Simply the best, and saying "To Hell with the rest!"
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Advertise Here
