Fuel
#1
Posted 26 September 2009 - 02:41 AM
I have a 2003 Chevrolet Suburban K1500 LT with a 5.3L 'Z' type engine. For the last 3-4 years it has consistantly used 13-14L of fuel per 100 Km. It is always regularly serviced. For no apparent reason it is now using 21-22L per 100 km. It has been scanned and the error code PO178 came up, a new costly fuel composition sensor has been installed and still no let up with high fuel consumption. Instantanios figures at idle go to 99L / . even under extremely gentle excelleration it goes to well over 35L/p/100km. when im just coasting there is no drag at all, it does'nt smell of fuel.
Can anyone help. I live in the Northern Territory of Australia and no one wants to go anywhere near it.
#2
Posted 26 September 2009 - 05:35 AM
Wish I could be more specific, but these things are tough to diagnose over the internet.
Hope this helps somewhat. Good luck.
Edited by Jsdirt, 26 September 2009 - 05:36 AM.
#3
Posted 26 September 2009 - 05:51 AM
#4
Posted 26 September 2009 - 06:03 PM
If so try these links
http://www.automotiv...topic488158.htm
http://www.automotiv...om/t359623.html
1999 Chevy Camaro Z28 (Mr. Hyde)
2004 Honda Civic (Dr. Jeckel)
#5
Posted 26 September 2009 - 09:01 PM
new plugs and wires may be a good help too if you haven't changed them before. They are due to be changed at 166,000km but can go bad earlier. Replace the plugs with NGK TR55, platinum.
At idle you will get a reading of 99L/100km always..because you aren't going anywhere really you are burning infinite fuel /km but the system is set to show 99L
another reason for this could be from the fuel you use. if you buy fuel with higher amounts of ethanol as fillers you will reduce your fuel economy.
Hope this helps
Cheers;
Aiden
so you expected something that weights 5000 pounds and has aerodynamics of a piano to get what?
2003 Silverado XCSB, 4.8L, Flowmaster super44 SI/DO, G80 3.42, MSD Wires, K&N drop-in filter, Yellow Top Battery, Royal Purple in entire Drivetrain, W4M tune....My DD..............................SOLD
2010 Silverado XCSB 5.3L Z71 Summit White, Diablo Trinity tuned....more to come soon.
2010 Cobalt 2.2L LT 2Dr. Victory Red....gas saver/wife's Car.......SOLD
2011 Cruze 1.4L Turbo 1LT Crystal Red ...Again, Wifes car and gas saver
1978 LJ80, 16V 1600cc on 31's, Spring over lift, awaiting Full Frame off build...The Toy
#6
Posted 28 September 2009 - 07:48 AM
Thankyou for clarifying the instantaneos figures on idle, i never really took much notice of those numbers, as i have always been very happy with the average fuel figures. New plugs and filters hae just been Changed. I always run premium fuel 95 or 98 but the finance manager likes the look ($$$) of the standard unleaded. I have been reading up about a "Seafoam" product that is designed for upper engine cleaner. Have you or any one else had any experience with this cleaner and if so can you tell me how it went.
Cheers Matthew.
#7
Posted 30 September 2009 - 08:46 AM
Just disconnect the vacuum line from your brake booster and siphon the Seafoam in to the intake from there...probably the easiest way to get it in there.
Just follow the directions on the bottle.
#8
Posted 30 September 2009 - 09:26 AM
My guess would be the following:
The fuel companies are putting more ethanol into fuels now due to strict environmental/pollution standards. My fuel economy definitly goes down when they switch to the winter blend of gas as well.
What type of Spark Plugs did you put in? I've found that I get the best performance/fuel economy with stock AC/Delco plugs. None of that fancy Shancy aftermarket spark plug nonsense. Change the plugs around 75,000 miles. I don't buy that 100,000 mile plug interval nonsense.
Change the Plug Wires if your truck is between 85,000 - 100,000 miles. (not sure what the conversion is for your neck of the woods)
Running Seafoam won't hurt at this point. It is useless to run the stuff in your vehicle if it has less then I say 80,000 miles.
I'd run a bottle or two of a good fuel injector cleaner thru the truck as well, (I prefer Chevron Techron fuel injector cleaner and run 2 bottles a year thru my truck, in the summer, around July, and again in the winter, around December)
What kind of oil are you using? These gas engines do well with standard 5W30, and you can get away with 10W30, but don't use anything else. 5W30 will work great, either Synthetic, Synthetic Blend, or standard conventional. You'll not notice any difference in fuel economy by using Synthetic over conventional, contrary to popular belief.
Do as others have suggested, clean the throttle body, and air filter. Unless you drive in dusty conditions (dirt roads) you should really only need to replace that air filter once a year. If your truck has a fuel filter outside of the fuel tank, go ahead and replace it with a good quality part. AC/Delco or NAPA will work good.
How are your tires? Did you increase the tire size lately? are all properly inflated? You'd be surprised how much under or over inflated tires can mess with the fuel economy!
The O2 sensors may be starting to get old. Most 02 Sensors now a days have a heating element inside of them, they can start to go bad as early as 85,000 miles, however it may not always throw a check engine code/light.
Are there any problems with the exhaust system? a Cat Converter which is starting to plug up can cause problems as well.
GM- Simply the best, and saying "To Hell with the rest!"
#9
Posted 01 October 2009 - 06:41 AM
As far as the octane rating of the fuel, i am confident that our minimum down here is (91-enleaded)
- ( 95-Premium) & (98- ultimate). So do you recommend that i choose a fuel type and have it tuned to suit, and can this be done via the latest Snap on diagnostic epuiptment?.
#10
Posted 01 October 2009 - 06:51 AM
Cheers Matthew.
#11
Posted 01 October 2009 - 10:33 AM
my truck has a preprogrammed computer and I run 94 octane fuel that would be 99 for you guys. I get better economy with that fuel than the low or mid grade stuff. Actually 70-100km per tank enough to make up the difference in cost and than some.
Edited by Nytemare, 01 October 2009 - 10:35 AM.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
