Just need it for the front 1/4" lines , from the ABS unit forward.
I made a template when I took the old lines out but I want to double check .
Thanks in advance .
Posted 28 September 2009 - 01:34 PM
Posted 28 September 2009 - 07:36 PM
">Posted 02 October 2009 - 05:32 PM
Good luck on this one. I checked the factory service manual and it shows nothing.
Posted 02 October 2009 - 08:58 PM
Hm , thanks anyway .![]()
Looks like my diagram was wrong after all .
I went to bleed the system today and could not get fluid out of the drivers front brake line .
Ok so here is the part where I ask one of you guys to look under your 99-00 NBS truck and trace the 5 lines from the ABS forward . If you do this you will be my hero . It wont be easy and could possibly take 2 guys , but still it would rule .![]()
OR if anyone could just post a pic with the ABS pump / dist block and the locations that would work also . If I am correct that what I have done is swapped the first O with the last O .![]()
I think that the top 3 lines are fluid outs and that the bottom 2 are for the master cylinder . The third O is for the rear brakes , this is for sure , and the second O is for the pass front . The arrangement is like this looking at the dist block on the front of the ABS .
0 0 0
0 0
0 members, 0 guests, 0 anonymous users
