Stuck Lifter On 5.3
#1
Posted 20 January 2010 - 08:24 PM
Ticking sound, like a stuck lifter, remains constantly. It used to come on at first crank then go away; it doesn't go away now. I've tried a few additives from Lucas and SeaFoam; to no avail.
Is this constant stuck lifter (assuming it is) damaging? Suggestions for remedy?
What fixes this?
Thank you all.
---Bryant
#2
Posted 20 January 2010 - 08:37 PM
You have to remove the intake, rocker covers, the push rods and than take out the old lifters and pop in new ones. Probably under 400 bucks if you can do it all yourself.
Is it going to hurt anything...probably not....if your driving with your foot to the floor all the time maybe.
Is it ideal...no....but you'll probably get years out of it yet with it just like it is.
so you expected something that weights 5000 pounds and has aerodynamics of a piano to get what?
2003 Silverado XCSB, 4.8L, Flowmaster super44 SI/DO, G80 3.42, MSD Wires, K&N drop-in filter, Yellow Top Battery, Royal Purple in entire Drivetrain, W4M tune....My DD..............................SOLD
2010 Silverado XCSB 5.3L Z71 Summit White, Diablo Trinity tuned....more to come soon.
2010 Cobalt 2.2L LT 2Dr. Victory Red....gas saver/wife's Car.......SOLD
2011 Cruze 1.4L Turbo 1LT Crystal Red ...Again, Wifes car and gas saver
1978 LJ80, 16V 1600cc on 31's, Spring over lift, awaiting Full Frame off build...The Toy
#3
Posted 21 January 2010 - 05:11 AM
While I can fly the hair off of a $10 million BlackHawk, I've never tackled something like that; but I'd really like to.
I'll check out some of the available repair manuals and see if they bestow confidence.
I have a small farm and can repair things and am reasonably mechanically inclined.
Whadda ya think? When I do repair it, should I trust the manuals and my confidence?
#4
Posted 21 January 2010 - 07:52 AM
Not a bad job at all. Just take your time and enjoy yourself.
#5
Posted 21 January 2010 - 03:48 PM
Haynes manuals are the easiest to read and understand...Chilton's are more comprehensive...but are written more for guys with a background in mechanics.
Make sure its a sticky lifter first...it could be just injector tick...have a good mechanic listen to it...also try tossing some seafoam in the fuel...see if that helps...that will tell you if its an injector.
#6
Posted 26 January 2010 - 10:55 PM
#7
Posted 26 January 2010 - 11:00 PM
Actually, you need to remove the cylinder heads to replace lifters on a 5.3L. Another thing, the rocker arms have needle bearings that tend to fall out. This can cause noise and misfires.
The heads do need to come off but it's a pretty easy head to tackle. I have yet to see needle bearings on these rockers come out. It was an issue on the 3.8 and 3.4 of the late 90's and early 2000's but I have not seen one missing on a 5.3 yet. How many have you seen come apart?
and
If at first you don't succeed suc harder.
#8
Posted 26 January 2010 - 11:12 PM
There is a TSB out for it also.
These heads are very easy to pull indeed, one of the easiest V8 engines to work on.
#9
Posted 26 January 2010 - 11:19 PM
I've seen quite a few, mostly 99-00 4.8's and 5.3's.
Crap he said 2000, I was thinking this was a newer one. I didn't work on many trucks back then almost straight Pontiac work till 2005. My bad you are right.
and
#10
Posted 26 January 2010 - 11:21 PM
#11
Posted 26 January 2010 - 11:25 PM
FOUNDER of the RED TRUCK CLUB .
#12
Posted 26 January 2010 - 11:29 PM
#13
Posted 26 January 2010 - 11:54 PM
6.0 - 4.8 - 5.3 are all the same basic design. Many 5.3s are going well over 300K. I'd assume the 6.0 and 4.8 should do the same.True that. We seldom see any with over 250k roll through the shop. I know the 6.0L's go easily over 300k, not sure on the smaller versions.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
