  • 0
alkaspeltzar
2010 Silverado Oil Pressure
Question
I have a 2010 Silverado 5.3L. At normal operating temp, the oil pressure is at 25-30 psi at idle. At crusing speed, 65mph(1500rpm) it is about 40 psi. Is this normal for the new truck, thought it might be higher?
Can you tell me what the specs say the truck should have for oil pressure at both cold temp and operating temp?
Thanks for your time, I appreciate it!
Share this post
Link to post
0 answers to this question
if it makes you feel better,see the service manager and get a print out of the specs ,the shop foreman will do it as well
Share this post
Link to post
About half way up the gauge at idle...maybe a little below.
Share this post
Link to post
you can also have them put on a master gauge to the test port if the specs you get do not jive
Share this post
Link to post
I recently tradeded a 2002 Silverado 5.3 Extended cab for 2009 5.3 Crew Cab and have noticed a difference in oil pressure also. My 2002 ran about 60 psi most of the time and the 2009 runs at idle around 20-30 and at crusing speeds around 40.
Share this post
Link to post
SO your 09 is basically running the same as mine. That is nice to know. I have a family member with an 01 sierra, that is also why I noticed the difference.
Anyone else have an 09 or 10 that runs this way? guess knowing that is how they are running from factory puts my mind at ease. Thanks
Share this post
Link to post
