  • 0
iam4uf
2005 Yukon Rear Wheeling Bearing
Question
Hi, I have a 2005 Yukon XL with 80,000 miles. I went to the service garage for a tire rotation and they told me that I need the left rear wheel bearing and axle seal replaced. He should me oil on the back tire. He gave me a quote of $600 for both side. I am a shade tree mechanic and was wondering if this is hard to replace. Thanks in advance.
By the way, here is what the ship stated I needed:
DK59047 Rear Wheel Bearin
16146 Rear Wheel Seal.
Share this post
Link to post
0 answers to this question
Not hard to replace at all, if you can knock a bearing and a seal out a housing with a screwdriver and a hammer and then tap em' back in. You SHOULD be able to buy the bearings and seals for less than $150, unless you go with gm parts, then they'll run around $300 or more(just for the GM name, quality will be the same). As long as the bearings are made by timken or koyo, they'll be alright.
Share this post
Link to post
They quoted me $95.45 each for the Wheel bearing and $19.04 for the seal. I think I will give it a shot. Hopefully it wont be that hard to do.
Share this post
Link to post
That's a ton cheaper than $600! You're a man, you can do it! If in doubt, you can keep thinking of that statement. :troll:
Share this post
Link to post
+1
Share this post
Link to post
The parts place was asking me what type of axle I have. I have no idea. Do you know how to find out. The only info on the pumpkin is 8857 and a stamp of PG2. Thanks
Share this post
Link to post
Look in your glove box at the codes and post me all the codes that start with a g. Also count the amount of bolts on your rear end dif cover.
Share this post
Link to post
GU6, G65, G80
10 bolts on diff cover
GU6=3.42 gears in rear, G65=self leveling ride shocks(basic package), G80=Locking differential. Looks like you do have the regular 10 bolt AAM 8.6" rear end. Standard rear end.
Share this post
Link to post
Great, thanks. Looks like my local auto parts has them in stock. $30.99 for bearing and $7.99 for seal. Thanks again
Share this post
Link to post
Good deal!
Share this post
Link to post
