tooch420
Torsion Leveling And Tires...
What is the largest tire I can fit in my 2500HD 4x4 with a 2" torsion key lift. I want to keep my stock rims that are 16"
Share this post
Link to post
With T-bars cranked all the way, you just can put a 305 on there.
Share this post
Link to post
cranking the stock keys or re-indexed keys?
Share this post
Link to post
305 is a squeeze and may rub a little bit with stock keys, but will be just fine with 2inch lift keys
Share this post
Link to post
I've got an 04 gmc with a leveling kit in the front and 2" blocks in the rear and I've got 305/70/16 on stock 16" rims and they fit fine. I had to trim a 1" corner of the front bumper but the gmc bumpers hang down alot
Share this post
Link to post
i have a 1500HD which is lower than a 2500HD, i cranked stock keys and got airbags in the rear keep them at about 25 PSI lifts the truck about 2 inches. i got 33x12.5's on 18 inch rims with a pretty aggressive offset. little bit of trimming but they are okay. barely rub sometimes, only in reverse cranked the one way, and its minimal.
Share this post
Link to post
I just got a 2010 2500hd cc 4wd if I buy new keys/leveling kit for the front and lift it 2" do you guys think 295/70/17's (33.19"x12.13") or 285/75/17's (33.86"x11.30") will fit on stock rims, they are terra grappler's I used to have an 03 hd with 16" 285's and they would only rub because of the width. Is is better to go a little taller and skinnier or a little shorter and fatter; When it comes to tires that is!!!! Any info will help. Tks
Share this post
Link to post
Narrower. You will still have to trim a bit
Share this post
Link to post
I have had 305 BFG MT's on my 16" factory wheels for 5 years and 46,000+ miles with no issues. They do rub at full lock on the passenger side anti-sway bar. And you have to zip tie the parking brake.
Check my pics.
Share this post
Link to post
Check my pics.
All you did was crank the torsion bars up? Or did you use different keys?
Share this post
Link to post
  • Choose your favorite 2019 trim level   142 members have voted
    1. 1. Which trim level do you want to buy your 2019 Silverado in?
      • Work Truck
      • Custom
      • Custom Trailboss
      • LT
      • RST
      • LT Trailboss
      • LTZ
      • High Country
    Please sign in or register to vote in this poll. View topic
  • Images
  • My Clubs
