haulincats
1987 350 Tbi High Idle
I have an 87 350 TBI and it idles about 2,000 rpm's
I don't see any way to adjust it.
How do I get it to idle down?
Thanks,
van
Share this post
Link to post
Thanks,
van
Sounds like your IAC valve is bad.
Share this post
Link to post
Check for a vacuum leak. Mine was like that when I bought it and it was the throttle body gasket, or should I say the lack of one.
Share this post
Link to post
Thanks,
van
What is that, where is it and how do I check it?
Thanks,
van
Share this post
Link to post
Do you mean the gasket between the throttle body and the intake manifold?
Thanks,
van
Share this post
Link to post
Thanks,
van
Thanks,
van
It's a valve that sets how much air enters your engine at idle with a solenoid that goes in and out with a rubber tip on the end. If you unplug it and notice no difference, then it's that. It's located on the side of TB and has 4 wire connector hooked to it. The body of the valve is shaped like a big nut for a wrench to turn. If it does make a difference, then it's good. To check, turn the key to the run position then unplug IAC, then start truck and look for differences in idle speed. Plugging it up while running will result in nothing different even if the IAC is good.
Share this post
Link to post
Thanks,
van
Yes, Thats the one. You may just want to buy the TBI rebuild kit. its very inexpensive.
Share this post
Link to post
