Mazer18
Squeal Noise Coming From Under Truck
I've had this squealing noise coming from underneath my truck for a few months now. I thought it was coming from the front left wheel area but I'm not sure. I can usually recreate the squeal if I make a right turn with a little speed it will let out a 2-3 second squeal until I finish the turn. I can't recreate with a left turn.
I also get the noise if I drive real slow. If I just let it coast from a stop it will make the noise. But when I do this it isn't a constant squeal. It is just like a squeak, squeak, squeak almost like there's a certain point in the wheel's rotation that the sound is being created from.
Something I noticed this afternoon; If I apply the brakes, even very lightly, the noise will stop. As soon as I let off the brakes the noise comes back though.
I do have a RC 2" level on but I don't think it's the ball joints. I tried shaking the left front tire with it jacked up and couldn't get any movement. Didn't try the right front.
Any ideas where to start looking?
Share this post
Link to post
Have you looked at the wheel bearing and brakes?
Share this post
Link to post
I'm not real familiar with the front suspension components so I don't really know where to look. I'm due for service soon so I figured I'd get a few suggestions here and when I'm at the dealer just say "by the way could you inspect the ------" and see what they say.
Share this post
Link to post
Check the brake pads. Could be your wear indicators. Also have the u-joints checked.
Share this post
Link to post
Had it looked at today during routine service along with a window squeal.
The service manager told me that there was a large rust ridge built up on the rotor (I assume brake rotor?) that was grinding during turns and that they scrubbed it off. There is one spot in town I can always recreate the noise and I tested it today and the first time it didn't make the noise; second time it did. :lol:
I have to go back to get a new part for the window squeal in a few days so hopefully the rotor is just working debris or whatever out and I won't have to have them look at it again. Hopefully.......
Share this post
Link to post
