04_5.3 Posted December 28, 2010 Share Posted December 28, 2010 Im getting a 1345 code on my 98 gmc 2500 with a 5.7? So how can I fix it? it idles fine but sometimes going down the road it spits and pops and has a stall to it. So has anyone ran across this before if you have let me know asap Thanks Link to comment Share on other sites More sharing options...
sc15pro Posted December 29, 2010 Share Posted December 29, 2010 Im getting a 1345 code on my 98 gmc 2500 with a 5.7? So how can I fix it? it idles fine but sometimes going down the road it spits and pops and has a stall to it. So has anyone ran across this before if you have let me know asap Thanks My book said camshaft to crankshaft position correlation fault.Sounds to me like one of the sensors is getting bad or a bad wire and at just the rite time one of them looses a signal.Check the connections and wires for bad spots. Link to comment Share on other sites More sharing options...
04_5.3 Posted December 29, 2010 Author Share Posted December 29, 2010 Im getting a 1345 code on my 98 gmc 2500 with a 5.7? So how can I fix it? it idles fine but sometimes going down the road it spits and pops and has a stall to it. So has anyone ran across this before if you have let me know asap Thanks My book said camshaft to crankshaft position correlation fault.Sounds to me like one of the sensors is getting bad or a bad wire and at just the rite time one of them looses a signal.Check the connections and wires for bad spots. Thanks I will check it someone around home was telling me someone didn't put the dis back in wrong. This sounds stupid but I can turn the dis clockwise to get the check engine light off. But then going down the road the tq converter want lock in. At 60 mph its running 2300 and it should be running at 1900. So does anyone know what is up with it. The trans is a 4L80E Link to comment Share on other sites More sharing options...
233monte Posted December 30, 2010 Share Posted December 30, 2010 You need a scanner to check timing On these engines. That should point you in a direction. The CMP pid should be no more than + or - 2 degrees or it will set the 1345 code Link to comment Share on other sites More sharing options...
twavor Posted December 31, 2010 Share Posted December 31, 2010 Did you have the distributor out or have you moved the distributor just prior to this code popping up? The distributor has to be in just right or you will get that code. Travis Link to comment Share on other sites More sharing options...
