- 0
Key Will Not Turn In Ignition
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 18 Members, 0 Anonymous, 2,062 Guests (See full list)
Question
maxattack
Hey all,
Odd problem here. I have an 01 Yukon (its a Denali XL if that matters) and all of a sudden the key will not turn in the ignition tumbler. Never had any signs of an ignition switch issue before, the steering is not locked, it is all the way in park (I took the cover off and can see the pawl on the column) and I have tried both keys that are programmed to the truck just in case and that didnt work either.
I called my local locksmith who is great, all the local shops and dealers use them to ask if they had heard of this. He said he had, and that if I can get the tumbler out, odds are its a simple fix. The tumbler doesnt release unless youre in the run position, so somehow this key has to turn forward. I have tried the tricks of compressed air, lock lube, tapping on the key (gently) and nothing has worked. Key comes in and out like normal but doesnt budge when you try to turn it.
Any help would be great, Id like to get this thing outta the driveway ASAP before the g/f gets ideas about taking my C5 to work because the truck is blocking in her car!
Thanks much,
Brandon
0 answers to this question
