Fitting 35 Inch Tires
#1
Posted 08 August 2011 - 01:43 PM
#3
Posted 08 August 2011 - 05:33 PM
#4
Posted 08 August 2011 - 07:00 PM
Most likely going to be Cooper Discoverer 35x12.5. Fitting to me is not having to cut anything down to change its cosmetic look really.
Well the right way to do it would be a 6" suspension lift.
#5
Posted 08 August 2011 - 07:08 PM
#6
Posted 08 August 2011 - 08:23 PM
2007 Z71 Classic Crew Cab
2" lift front and rear, 285/70/17 tires, Magnaflow muffler, Air-aid intake, 4.10 gears
#8
Posted 09 August 2011 - 03:06 AM
#9
Posted 09 August 2011 - 10:40 AM
I am probably going with a Pro comp wheel 17x9 looks like its a 4.75 backspacing with -6 mm offset. I am not sure what backspacing or offset is needed. I recently found a post a guy with a 2500hd GMC 2007 who was able to fit 35 inch tires on with only his torsion bars turned up and longer shocks added and only needed minor trimming on the inner fender liners.
What were the wheel specs? That makes a big difference. Also, just in case you haven't seen any, body lifts don't look so hot on HD's. The amount of frame that will be showing is quite a bit.
Edited by Blackout07, 09 August 2011 - 10:41 AM.
#10
Posted 09 August 2011 - 01:33 PM
#12
Posted 09 August 2011 - 02:38 PM
#13
Posted 09 August 2011 - 04:19 PM
I've read too much about how much more stress it puts and how bad of a ride it is. With the leveling kit it relocates the front shocks to help with the ride.
ehh its does the same thing in the end.. crank it
Edited by stlavsa, 09 August 2011 - 04:19 PM.
#14
Posted 09 August 2011 - 04:48 PM
You didn't read enough
The "leveling keys" put exactly the same stress and result in the same exact bad ride. They just lighten up your wallet some. ONLY reason to ever put keys on is IF you can't get the height you want from the stock keys and want to crank further.
Edit: which, by the way, means that leveling keys actually result in MORE stress and WORSE ride than the stock keys will allow.
Edited by Matt_, 09 August 2011 - 04:49 PM.
2007 Jeep Commander 5.7L Hemi: Pics Here
2008 GMC Sierra Denali AWD (SOLD):Pics Here
2005 1500 Crew Cab. 8" lift w/37s (SOLD): Pics Here
#15
Posted 09 August 2011 - 05:44 PM
You didn't read enough![]()
And, you dont need the shock extensions if you stick to a reasonable lift with the stock keys.
Someone is blowing smoke up your shorts to get you to buy all the extra stuff you dont need.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
