ggodwin
2009 Sierra 5.3 Low Oil Pressure symtoms but actually OK
I have a 2009 Sierra 5.3L. The oil has been changed every 5K miles. A couple changes I may have exceeded that limit and gone past to 8K. But, it has been changed about 15-17 times since I owned it.
This morning I was on a steep grassy incline and suddenly the low oil pressure indicators came on.The oil pressure gauge would fluctuate around 40 based on the RPM then suddenly drop down around 0. Prior to that occurrence, the vehicle was facing front down on a driveway which rarely happens. (not steep at all) Normally, the front is elevated. When I started the engine it had the momentarily engine clicking which it has done in cold weather. However, that noise was momentarily. I drove approximately 2 miles to the steep grassy incline when the problem first occurred.
After the first indicator I moved the vehicle to level ground and evaluated the condition. The engine was indeed low on oil. I added 1 Qt and re-evaluated. The issue seemed to go away. However, after driving back the 2 miles the problem recurred. Through out all of this the ENGINE NEVER made a ticking noise as if it were low on oil.
DEALER REPLACED THE OIL PRESSURE SENSOR $368
Next Issue
Yesterday I took my Sierra into the dealer and he ran the codes.
Some of these codes are NOT related. However, just for the total picture I will post them also.
P0 Code - Dealers comments
P0521 - Oil PSI Sensor
P0555 -
P0449 - Vent Solenoid
P0442 - Smell (have no idea what smell means)
P0446 - PSI Sensor
P0335 - Crank Sensor
The check engine light was already on because of the fuel tank leak/Fuel cap leaking etc..
I did not have the money to have him repair every issue. I believe I can save a lot of money doing some of these myself.
I did have them fix the issues related to the Oil System. (No chances taken).
They repaired the Oil Pressure sensor.
Approximately 75 miles down the road the problem recurred. As I was pulling off the interstate and the RPM's dropped I noticed the Oil Pressure gauge drop down to around 15 psi. just as I was stopping the warning's came on again to "Stop the Engine" because there was NO oil pressure.
I can tell when the engine is low on oil as the lifters/valves etc.. start ticking/rattling. There was NO sign the engine was in any danger. As I drove the next 150 miles getting home the oil pressure would fluctuate. When the sensors would indicate a pressure drop the the alarms would sound and the lights start flashing. I could get a temporary relief from the issue by turning the engine off and restarting. Today the issue has occurred just one time. However, I have noticed that the Oil pressure is dropping down around the 15 psi mark. Also, moment ago i heard two sounds that sounded like a "back fire" up into a Carburetor. (Air popping noise) on the 2nd pop the Traction Control error came on the truck felt like it was in 4 cylinder mode. This lasted for maybe 1 mile when the truck starting driving normal again.
Any ideas on this issue?
Share this post
Link to post
That's quite an array of things going on. I wonder if you have a bad ground somewhere.
DEWFPO
Share this post
Link to post
I wonder if the pick up came off in the sump. Some of the same symptoms my dads 1996 yukon exhibited and that was his issues.
Share this post
Link to post
This was the last weekend of deer season and my dad needed to get his stand down.(I dont off road or anything...this was not rough terrain) Because my truck is 4x4, I drove up a very steep logging road and this issue triggered at the top. On the way to this location I was parked in the driveway 2 miles away and when I started the engine it made a lifter ticking noise. (Which it does this from time to time)
When we came down I found the first level spot and shut it down and checkecd the oil. It was low so I put a Qt in. (I dont know why but there was one in my Hunting gear trunk) After this the level was fine and I continued. Initially it was fine, but a short bit later it started again. Now we are at home and we checked the oil level again and it took another Qt at that time. This was very little driving in between the Qts.
For now lets forget all the other codes. My check engine light always came on. I assumed it was a gas cap and never had it checked.
Based on that I would say yes, it did consume some oil. I get it changed at Valvoline Instant. I think I use the 5W30 Durablend oil. I have no idea what filter they use.
Share this post
Link to post
I don't think I had a 5 year warranty. The vehicle has 90,000 miles on it. I have a 1000,000 mile power train warranty. But, electronic sensors are not considered power train.
Share this post
Link to post
no but engine oil consumption is...
Share this post
Link to post
i would think it would be in the manufacturers best interest to ensure that the oil pressure warning system is working correctly. It could just as easily show 45psi when in fact there is none.
Share this post
Link to post
Time to take it in and have them run it with a mechanical gauge attached. Probably has some plugged up screens in the AFM manifold or the pickup tube seal is leaking.None of it is any matter to you though because all engine mechanical is covered 5/100. Take it in.
Share this post
Link to post
While I'm waiting on the service mgr to call me back. What exactly is an AFM filter.
Thanks
Share this post
Link to post
A screen that is in the AFM manifold oil passage right in front of the oil pressure sending unit. They are known to get plugged causing low oil pressure readings.
Share this post
Link to post
I'm really curious to hear what this is, I had almost an identical situation to yours and I had the oil changed and it hasn't happened again. I still get the lifter noise on start-up and I've been noticing that I am about a quart of oil low every few weeks. My truck is also a 2009 5.3 with about 54k on it.
Share this post
Link to post
Mine has always had the lifter noise. However, i did notice that it was really loud when I started it on the time this problem occured.
I got a call from the dealer that did the work on Monday. As it turns out, the service manager is a friend of mine from High School. He told me that there is a problem with these engines that require oil to be shot/squirted into the bottom of the cylinders etc...etc... yada yada yada.
Anyway, there is a service bulletin for these engines that have fluctuating oil pressure that requires a kit be installed. In some cases the kit is not enough and new pistons and rings are required. It sounds like GM did not do their home work with their reliability testing. I am sure we can find the service bulletin on the net some where. The Service Manager said that they would refund all the work that was done replacing the oil sending unit.
After talking to him, I took my truck by the local GMC dealer and explained the long list and details of the failure mode. We made an appointment for the tomorrow to bring the truck in. As I was driving there the truck started running really rough. However, it was a "good" rough. If that makes sense. It never came close to stalling, it was just rough. The skid control lights came on again. The service guy told me that when something goes wrong, many times the vehicle will switch into a "safe mode". It shuts down many of the "systems" and allows the driver to reach safety and not get stalled. The skid control system was simply turned off therefore the indicators gave a warning. The check engine light was blinking at this point. He told me that a blinking check engine light is bad and we should not drive it. As I pulled out to go home the condition came back so I turned around and went back. He gave me a loaner and they will look at it tomorrow.
Update you tomorrow.
Share this post
Link to post
I had the same symptons on my 2009 Sierra, but they did not come and go, they just went. The truck would hardly run and all the alarms were going off and lights flashing. The truck had no power. I finally crawled into the nearest GM dealship. It was a Chevolet Dealer in a town about 55 miles from where I live. They had no idea what the problem was and could not repair that day. Rented a car and went home. Dealer called next day and had truck repaired. Two or three sensor had shorted out giving the computer bad readings. I would have to find the bill to let you know what sensors were bad. He said he had to replace all at one time for the problem to go away
Share this post
Link to post
  • Similar Content
    • By ElJefeBlanco
      I have a 2016 Crew Cab short bed. I had a bad flapper valve and they replaced the entire exhaust system about a month ago.
      I just ordered an aftermarket cat-back and will have it installed this week. I would like to unload the factory one.
      If anyone is interested, please let know and make an offer.
      I'm located in the DFW area, but will ship it to you (at your expense).
      If this is in the wrong section or not allowed, please let me know.
    • By L83_Z71
      Morning/ Afternoon,
      I have a question about over filling your oil with the newer silverado's. I recently just changed my oil since I got my truck about 3 months ago using the 0W-20 mobil 1. I put in 8 quarts exacly (without filling the filter). let it sit for a second then started her up. Truck ran for a couple of minutes then I shut it off, let it sit for about 10 min and checked the oil. I was not able to read the oil level as accurately as Im used to due to how freaking light the color of the oil lol, so light! I drove it for about a 100 miles, let it sit then checked it again. oil level was right above the hatch line if not right on it so I drained out just a tad to make me feel better then checked again. Now its sitting just above the top dimple but still within the hatch line area. So I guess my question is... Do  you think over filling that much would be enough to damage any internals or pump? Any insight is very much appreciated, thank you.
    • By Martiallterrain
      Hey guys I’m new to the forum but I’ve been a long time subscriber since I bought my 14 Sierra new in feb 2014. So I’ve read lots of horror stories on the site and I thought I’d tell you guys about my experience.
      A few weeks ago over 5r holidays, my girlfriend and I were returning a uhaul after moving and she was following in my truck, she called to say that the check engine light was on and the truck had reduced power. We dropped off the uhaul and I hopped in and could tell it was misfiring and had a rough idle. I took it to my local mechanic and he told me cylinder 4 was misfiring and he tried a coil pack but that didn’t fix it, he did a compression test and it was holding compression but he told me this was gonna be a bigger problem.
      luckily I still had powertrain warranty so I contacted the dealership that I bought the truck from and they had me tow it there using gm roadside. So my first hats off to gm, the lady I had on the phone from roadside assistance asked her manager to waive the tow fee as I was having it towed to my home dealership that was > than the 50 miles that they cover for free.
      Once the truck made it to the dealership, it only took the. A couple of hours to figure out I had a failed lifter and broken rod for cylinder #4. Now I was freaking out because I’ve read horror stories on this site about having to argue with regional managers for warranty work this significant and I’ve heard dealerships arbitrarily saying work isn’t covered under warranty for whatever reason. Thankfully I can say  my service advisor set me up with a rental the same day and reassured me that everything would be covered by gm. He did say parts were on backorder and it would take approx 2 weeks. Almost 2 weeks to the day, truck was ready to be picked up with 0 hassle the entire time.
      This is my 3rd truck with the 5.3 and the only time I’ve had a significant mechanical issue. The truck only had 85000 km (around 50k miles) sure I was PO’d that my truck was out of commission for 2 weeks but I was extremely thankful that gm stood behind their product and was able to fix the truck for me. The truck seems to run fine now but I don’t know if I will keep it as I don’t know if it will be the same or if the issue will reoccur. I do know that my next truck will definite be another Chevy or Sierra. I can’t wait to see the reveal of the new Chevy this weekend at Detroit!
      Jut thought I would post a positive warranty repair story and throw a kudos out to gm for making things right with me
    • By ObscureGlock
      Hey guys! Hoping I can get some help on this...my truck out of nowhere started making this horrifying noise on startup, primarily during cold starts. I’m very concerned.
    • By ARCH89
      Hey Everyone,
      I am about to pull the trigger on a 2017 or 2018 Sierra 1500 SLT. My main issue right now is do I  buy one on the lot with the standard V8 (5.3) or do I order one with the 6.2 L? I tow a 5000 lb travel trailer often and a smaller 10 foot utility trailer. I am coming from a Diesel Volkswagen Touareg with over 400 lb feet of torque. This will be my daily driver. I am not concerned about the money to upgrade the engine but more so whether It is worth it. I really like the power ratings of the 6.2 l but is it that much more noticeable than the 5.3? I don't want this truck to feel "slow" since I am coming from a torquey vehicle.
      Thank you
    No registered users viewing this page.
    Rons624
    Rons624
  • Who's Online   96 Members, 0 Anonymous, 515 Guests (See full list)
