98 s-10 blazer tranny help
#1
Posted 22 February 2012 - 05:09 PM
Thanks
#2
Posted 24 February 2012 - 03:27 PM
2010 Toyota Tundra Double Cab TRD Off Road 4x4 5.7L
-Flomaster 50 Series and Custom Dual Exhaust by Service Connection, Monson MA https://www.facebook...on/315368643831
-6k Hid's Hi/Lo/Fog Lights
-Toyo Open Country A/T's
1998 GMC Sonoma SLE 4x4 Ext. Cab
1991 Chevrolet K1500 W/T 4x4 Reg. Cab 4.3L
1986 Ford Bronco Eddie Bauer 4x4 5.8L H.O. (351 Windsor)
#3
Posted 24 February 2012 - 03:58 PM
Black 2013 Camaro 2SS/RS M6
Economizer 91 Jetta Turbo Diesel
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
#4
Posted 25 February 2012 - 01:30 PM
#5
Posted 26 February 2012 - 11:35 AM
if no codes,the clutch may be pooched
lmao.
I'm here all week ,try the Veal !!
Rob
#6
Posted 24 March 2012 - 06:15 AM
Shift solenoid? Just guessin....
you very well could have lost your shift solenoid.there are two in there just under the fluid pan very VERY easy at home fix.not sure about yours but some might have four solenoidsthe shift solenoid pump your fluid to make it shift.but a sudden jerk would indicate that your transmission is going.since its OBD II get it scanned.mine is doing the exact same thing.i have to put 'er in 1st then as i pick up speed i shift to a higher gear in my 1995 z71..someone told me it could also be an ignition switch gone bad..
Edited by K5MudDog, 24 March 2012 - 06:18 AM.
#7
Posted 24 March 2012 - 06:20 AM
#8
Posted 24 March 2012 - 08:51 PM
#9
Posted 24 March 2012 - 10:56 PM
you're not reading/listening
broken record off !!!!
lmao.
Rob
#10
Posted 25 March 2012 - 06:39 AM
sprag clutch?
#11
Posted 25 March 2012 - 11:15 AM
#12
Posted 25 March 2012 - 06:43 PM
#13
Posted 26 March 2012 - 09:06 AM
you are wasting your time but do what ever you want ,,,,,no codes means the ELECTRICAL CONTROL SIDE IS OK ,mechanical side not so good ,,,,,you get that ??
The fact that he can manually shift it and it works fine makes me think that it IS something electrical. If the gears for a certain gear position were bad, or there was a burnt valve in there, it would show all the time, not just when in D or 3. I know you said the fluid level was ok, but how did the fluid look? Was it thick and bright red? Or dark and thin, and maybe have bubbles? I would pull the pan and check it out under there. Its cheap enough to justify before going and spending big $ one a repair / replace. It sounds like you may have a stuck solenoid or a sticky valve in the transmission. But it could also be a gear position indicator, or something like the neutral safety switch. And even though you did get it scanned, the electrical signals may be ok for all the solenoids, but mechanically the solenoid may not be operating properly or could be worn out enough to where it doesn't operate within spec anymore. Which would show the computer as the solenoid being fine, but the valve attached to it may not be.
Also, only posting one time does not a broken record make.
#14
Posted 26 March 2012 - 11:49 AM
and there could be an electricle part taking too much power not allowing the solenoids to operate properly...
#15
Posted 26 March 2012 - 09:54 PM
im sorry nick ive posted more than once about getting it scanned ,but you are new here and that is what i meant ,cheers
lmao.
Rob
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
