Garage Door Spring Replacement
torsion spring garage door repair
  • Please log in to reply
14 replies to this topic
#1 jdubya
jdubya
  • Member
  • 710 posts
  • Gender:Male
Posted 30 July 2012 - 06:58 PM
Just wondering if anyone on here has any experience replacing a torsion spring on a garage door. This is the one that is located on the roller bar on top of the door as aposed to the extension springs normally found on the sides of the door.
The one on my door broke the other day and I have been considering replacing it myself due to the cost of having someone come out. Everyone that I called gave me the "those things are dangerous, you should really have a professional handle this" Which I would accept if I was a non handy type, but taking a look at it there doesn't seem to be much to it, as long as you are careful when winding the spring up.
I recall actually winding up a Wayne Dalton garage door torsion spring when installing an opener in my old house but it was a while ago. My question is if anyone has done it, is it easy or should I really just call a professional in for $250, (OUCH!)
07 Chevy Silverado LT 4.8L 1500
NCD Customs 2.5" Leveling Kit, 3" ReadyLift Rear Block Kit | 20% Front Window Tint | Fold-A-Cover G4 Elite Tonneau Cover | Kennwood Double DIN Navi/Multimedia System with MB Quart Component Speakers
#2 RyanbabZ71
RyanbabZ71
    Administrator
  • Senior Moderator
  • 15,459 posts
  • Name:Ryan
  • Gender:Male
  • Drives:2010 Chevy Silverado Crewcab Z71 6.2L
Posted 30 July 2012 - 07:54 PM
Seriously it doesnt matter how handy you are they are wound up and dangerous as all heck. I have heard of many close calls luckily no one I knew has been injured or killed. They all ended up calling a pro after the fact (after changing their shorts). All I can say is be careful if you do it yourself.
Ryan
2010 Silverado Crewcab 4wd Z71 6.2L V-8 (L9H) Flex Fuel 6 Speed Transmission Sheer Silver Metallic
2012 Camaro 2SS Convertible 6.2L V-8 (L99) Ashen Gray Metallic
My Garage: http://www.gm-trucks...gallery&user=56
Camaro Mods http://www.camaro5.c...ad.php?t=257256
#3 txab
txab
    Your worst fWONking nightmare
  • Moderator
  • 6,770 posts
  • Gender:Male
  • Drives:2004 GMC Sierra
Posted 30 July 2012 - 10:03 PM
You should have pro do it. But $250 is a little steep. Shop around
Posted Image
"When the people find they can vote themselves money, that will herald the end of the republic."
-- Benjamin Franklin
Posted ImagePosted ImagePosted Image
#4 K3LA-6.2L
K3LA-6.2L
    Formally known as 06z71silvy
  • Member
  • 1,540 posts
  • Name:Jerry
  • Gender:Male
  • Drives:2012 Silverado LTZ w/6.2L
Posted 30 July 2012 - 11:02 PM
x2
Traded my 2006 Silverado in!
I now own a 2012 Silverado LTZ w/ 6.2L!
Upcoming modifications include Nathan Airchine K3LA Train Horn. & many other mods!
Posted Image
#5 electricchiken7
electricchiken7
  • Member
  • 239 posts
  • Gender:Male
  • Drives:2007 GMC Sierra
Posted 30 July 2012 - 11:30 PM
Most places I tried wouldn't even sell me one. I did finally get one and installed it myself and am still around to tell about it but you might make sure you can purchase one first. They are dangerous though but not impossible.
#6 IanF
IanF
  • Member
  • 127 posts
  • Gender:Male
Posted 31 July 2012 - 07:22 AM
I've done quite a few and please read up on ALL the safety precautions and instructions before attempting this repair and make sure you use the proper tools and winding bars. It is only an half hour job in cramped space but one slip and you could be injured. Do not attempt this with noone around incase something does happen. The double spring ones are the worst to work on and you must know what you are doing. If you shop around it should be under a $100. The going price around here is $75 to install a whole new door with the springs and tracks.
2010 Silverado LS Cheyenne edition, 2WD, 4.8L, Crew Cab, Taupe Grey
LineX'd, HIDs, Extang Solid TriFold, Various LED Mods, Orange Programmable TPMS Sensors, DEPO Black surround headlights
#7 06SierraZ71
06SierraZ71
    Old enough to know that you're not!
  • Moderator
  • 2,194 posts
  • Name:Mark
  • Gender:Male
  • Drives:2006 GMC Sierra SLE 2
Posted 31 July 2012 - 07:40 AM
I'm pretty handy myself but I have to agree with the others, have the pros do it. I had one break in a previous, sounded like a gun went off in my garage. I wanted nothing to do with someone that had that much force behind it. Just my opinion, if you try it, please stay safe.
2006 GMC Sierra, 1500, SLE 2, Crew Cab, Short Bed, Z71, 5.3L (L59), 4L60e, 3.42 gears, G80, Auto Trac 4x4, Midnight Blue Metallic, Truxxx leveling kit, K&N air filter, Line-X bed liner, Tekonsha brake controller, Mastercraft Courser AT2 tires, Monroe Relfex Shocks. 100,000 mile club!
Have Fun and Enjoy the Reading!
#8 doug_scott
doug_scott
    Senior Enthusiast
  • Member
  • 1,705 posts
  • Gender:Male
Posted 31 July 2012 - 02:38 PM
As others have said, you can get hurt pretty easy, and not just from the spring. The fall from the ladder is not something that gets done with grace. One of the most dangerous parts of the job is the winding of the spring to set preload or counterbalance. You have to rotate the spring about 90 degrees with a short bar, then tighten the lock bolt while you move the bar to the next hole, or you use two bars and move one 90 degrees, put the second bar in the next hole, remove the first bar, rotate again, move the bars and so on. Easy to get complacent while doing it, and mixing the steps up. That is when that ungraceful dismount from the ladder happens, and the judges only give a score of 3.
#9 hd01chevy
hd01chevy
  • Member
  • 217 posts
  • Gender:Male
Posted 31 August 2012 - 04:58 AM
I've worked on doors for the last 6 years and am just curious why a door company would not sell you a spring.......
#10 flhpi-ohio
flhpi-ohio
  • Member
  • 11 posts
  • Name:Tom
  • Gender:Male
  • Drives:07 GMC 2500 HD 8.1 EXLB / 07 Chevy 3500 D/A
Posted 18 September 2012 - 08:54 PM
I just fixed/adjusted my girlfriends garage door last week. Yes, the spring is dangerous. Yes, you can do it.
The style that I adjusted was nice. Set the spring with the set screws then put a 1/2 inch socket on a drill and let the gear mechanism tighten the spring. First time dealing with this style and they are VERY nice.
#11 RyanbabZ71
RyanbabZ71
    Administrator
  • Senior Moderator
  • 15,459 posts
  • Name:Ryan
  • Gender:Male
Posted 18 September 2012 - 09:07 PM
Those are the safe springs that are DIY friendly
Ryan
Ryan
#12 sixathome
sixathome
  • Member
  • 345 posts
  • Name:Dave
  • Gender:Male
  • Drives:08 Sierra 1500 Crew Z71
Posted 19 September 2012 - 07:27 PM
I've done a few springs myself, one side broke so I fixed it and then a little while later the other side broke so I fixed it too along with other torsion springs. Yes they are dangerous if your not careful. Get the proper bars for winding, dia and length. I usually get the springs at a overhead door Co, just give them the length, dia and thickness of the spring and they usually put the ends on for you.
BlackBear tuned.
#13 Sierra in the Sand
Sierra in the Sand
  • Member
  • 87 posts
Posted 04 December 2012 - 06:47 PM
Geez! The spring is contained on the shaft, so it can't break and hit you. It could throw the tool you use to tighten it, if you screw up, but it's pretty simple. Go to the web site of the door company and download the directions. Follow them carefully, and save yourself $250! Then buy some good beer to celebrate afterward! The dangerous springs are the older style extension springs. If you don't install a cable to secure them, when they break, they can kill you! I had one miss me by inches! I'll take the torsion spring any day!!
#14 MNDave
MNDave
  • Member
  • 10 posts
  • Gender:Male
  • Drives:'05 Silverado Ext. Cab Z71
Posted 12 December 2012 - 06:53 PM
I have watched installs of these springs a few times. The next time I need one, I will be doing it myself.
Most important thing I learned from watching a pro is to have 2 winding bars.
2005 Silverado Z71 Extended Cab 5.3L Sport Red Metallic
#15 06_GMC
06_GMC
  • Member
  • 374 posts
  • Name:Brandon
  • Gender:Male
  • Drives:2003 GMC Yukon XL
Posted 12 December 2012 - 09:43 PM
I used to do this for a living and yes they are dangerous. No they do not fly off and hit you but that damn winding bar can slip and crush your hand. Sop around if you want the professional to do it or at least be very careful and purchase two winding bars that are made for the job at hand. But all in all its an easy job and anyone can do it, just make sure you get your cables set right or you'll have a door on the ground or on your car. Also one if it were me I would replace both since you are saving money anyway and the other is not far behind. And last but not least if you spray paint a straight line on the spring before you install it it makes it a lot easier to count your wind's!
'03 GMC Yukon XL SLE 5.3L 4x4 122K Wife's
'00 Mitsubishi Montero Sport 2X4 Beater
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Advertise Here
