Sign in to follow this
tooch420
How long should brakes last??
SORRY I MEANT "BRAKES"....HOW LONG DO BRAKES LAST?
For my 2500HD, how log should the front pads last?
Edited by tooch420
Share this post
Link to post
That depends more on you as the driver than anything else. If you drive agressively, or in city type driving, or tend to use brakes on hills vs gears then the brakes won't last as long. If all highway and gentle on brakes and use gears in trans vs brakes they will last longer. What do you use your truck for? What kind of roads (or lack of) do you drive on? How aggresive of a driver are you?
Not trying to be a smartalic but there is no forumla to answer the question. Personally I rotate my own tires and always do a brake inspection at the time to ensure I still have pads and shoes. My factories last about 60k, but that was a lot of highway driving. Now I drive primarily city type driving and only have 40k on these brakes and may not last quite as long.
Share this post
Link to post
it all really depends on how you drive and what kind of brake pads you have. if you live in a very hilly environment your pads will wear a lot fast from normal driving whereas if you live in florida where its all flat, its a lot easier on brakes.
some people have their original pads last to 80 100k. typically old people.
pads for me would last around around 45k if that.
Share this post
Link to post
As others said there is no set guide line on brake replacement as it all somes up to driving style,towing etc. You check your brakes and when its time to replace you replace them.
Share this post
Link to post
I had 186,000 miles on the brake pads on my 99 Chev. no noise or drag with them until I traded the truck off.:jester:
Share this post
Link to post
"How long should brakes last?"
That's like asking : How long should a roll of toilet paper last....... it depends on how you use it.
DEWFPO
Share this post
Link to post
DEWFPO
I use very little TP as I like skid marks, makes me feal fast with less friction.
Share this post
Link to post
Thats what I thought. My original OE pads were good for at least 40 or 50k. I know its a ridiculous question but I only ask because about 20k miles ago I had my shop do the front rotors and pads and I asked for OE HEAVY DUTY pads (I supplied rotors). Well 20k later I noticed my new rotors are starting to grind down uneven and putting lines in them. I am just pissed because I usually do them myself but for what ever reason I had them do it and I think these are just crappy pads.
I just did the rear rotors and pads and used Hawk Heavy Duty, I think I will have to put set on front.
Share this post
Link to post
sometimes you get a set of pads that will wear really fast. i have had good luck with federal pads
Share this post
Link to post
never heard of them, are they ceramic or semi-matalic?
Share this post
Link to post
Guess I must be old :P I have 70k on mine and haven't thought about replacing them.
Share this post
Link to post
My 02 1500 had 50k and still were thick. I replaced them because they had cracks in the pad material. If I wouldn't have pulled the caliper and looked I would not have changed them until 70-80k. My commute is 4 mi round trip on a country road, I drive fast but never use much brake.
Edited by NUKE_1
Share this post
Link to post
Depends on your driving. On my '01 2500HD I had 90k and hadn't changed any parts on the brakes. On my '06 I'm above 70k and still all original. All depends on how you drive.
Share this post
Link to post
