Sign in to follow this
CRSilverado
1/4 mile time for 6.2 1500 Silverado?
I ran a search but did not see a 1/4 mile time listed for a stock 6.2 1500 Silverado.
Will one hang with a 5.0 F150 Ford? I found a 1/4 mile time of 14.9. I know the 5.3 won't run with one but will the 6.2?
Edited by CRSilverado
Share this post
Link to post
www.gm-trucks.com/forums/index.php?showtopic=148588&pid=1297418&st=0entry1297418
This with minor work on an Escalade. I've heard 14.5-14.6 in most cases.
Edit: Found this also:
Edited by SILVERADOSC540
Share this post
Link to post
15.520 sec @ 94.133mph
so long
j-ten-ner
With only a 15.52 1/4 et I better watch out for those 5.0 Fords! My son has a 2012 5.0 Ford truck and I was wondering how my 2013 6.2 would hold up against his. Looks like my 6.2 would need mods to beat that little 5.0!
His is a crew cab and mine an extended cab. Don't know the weight difference.
Share this post
Link to post
CC 6.2's should run in the mid 14's, tunes and some boltons drop them in the high 13's.
Share this post
Link to post
...Looks like my 6.2 would need mods to beat that little 5.0!...
Hook up a 10000lbs trailer to each truck and you'll see which one is better.
And if you wanna race go get a Corvette or something like that what is designed for race.
so long
j-ten-ner
Share this post
Link to post
So my stock 6.2 extended cab should run 14s! That's more like it.
Hook up a 10000lbs trailer to each truck and you'll see which one is better. And if you wanna race go get a Corvette or something like that what is designed for race. so long j-ten-ner
Share this post
Link to post
Now you have a hot 6.2! Want to race a stock heads/cam Corvette?
Only if you put 3000 pounds in the back of it. :) I guess we could race heads up- on snow. ;)
It would be fun just to get a gauge on where I'm at.
Share this post
Link to post
Not fair, I only need 1578# to equal your hp/wt ratio. I'll have to find a 1578# block of lead!
Share this post
Link to post
Your Vette is no Yugo. I was just looking for 1500 extra pounds for you...
Share this post
Link to post
