Sign in to follow this
Rocko973
Oil Pan Drain Plug Torque
Could someone kindly tell me what the torque spec is for the oil pan drain plug on a 2003 1500HD CC Silverado? Is it 18 lb ft? I know... I've read that a lot of people don't like following the torque spec on the plug because of its inaccuracy for a wet oily plug, and so they just go with their gut feeling for tightness/snugness, but I am just curious. I at least just want to use it as a reference...
Thanks in advance!
Share this post
Link to post
You don't need to torque a oil pan plug, just run it in till its snug and give it a little pull on the wrench.
Share this post
Link to post
It's 18 lb ft
Edited by txab
Share this post
Link to post
Yeah, your method falls right in line with a lot of people as I discovered when I did a search for the torque spec. In fact, that's how I've always done it too for many years, and only one time I over-torqued it and it was on a Dodge Caravan many years ago.
One poster was vehemently against using the torque spec because the spec is for a dry plug, not a wet oily one as you get when you change the oil. He said what you said, just snug it up, then a little pull. But I still wanted to know what GM recommends... Thanks!
It's 18 lb ft
Cool... thanks, txab! I appreciate it...
Share this post
Link to post
Here is some more info for your vehicle along with the drain plug torque spec.
Share this post
Link to post
Very cool, thank you! Does it matter if mine is a 6.0L?
Share this post
Link to post
No, it is still the same. If you want just click on your engine size over to the left and it will bring up everything for that application.
Share this post
Link to post
