BruceDeuce Posted May 28, 2013 Share Posted May 28, 2013 Will you see the red through the grill? Link to comment Share on other sites More sharing options...
Chris Posted May 28, 2013 Author Share Posted May 28, 2013 Will you see the red through the grill? maybe Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2 Link to comment Share on other sites More sharing options...
Chris Posted May 31, 2013 Author Share Posted May 31, 2013 Next mod. Just waiting on my bushings to arrive. Ordered new Energy Suspension urethane bushings for the leafs and shackles. Should get them tomorrow. I am trying to get my friends dad to straight swap his 3.73 G80 axle for my open 3.42. It works out for both of us because he just uses his truck as a daily driver. I have to tow a massive trailer in July. The very trailer I thought would kill the 4.8 and 4L60E(with no factory trans cooler) back in 2011. I have the power now, I have the trans cooling, I just need the axle. Link to comment Share on other sites More sharing options...
Carder09 Posted June 1, 2013 Share Posted June 1, 2013 Did you plan to also do an add-a-leaf too for that extra support? Link to comment Share on other sites More sharing options...
Chris Posted June 1, 2013 Author Share Posted June 1, 2013 4 leafs plus overload is sufficient I think. I got these for $100 for the pair Link to comment Share on other sites More sharing options...
Chris Posted June 1, 2013 Author Share Posted June 1, 2013 I am curious about the amount of lift it will provide the rear. I have a 1.25" block, I wanted to get a 2" block to add a little rake back to it, I am at about 1" of rake right now and my horse trailer makes it sag. But, this trailer I am prepping for has been on my truck before with the 4.8 and no trans cooler at all. My current leaf springs are almost flattened. Link to comment Share on other sites More sharing options...
Carder09 Posted June 1, 2013 Share Posted June 1, 2013 That's why I was wondering if you planned to add an add a leaf to prevent that. Link to comment Share on other sites More sharing options...
Chris Posted June 1, 2013 Author Share Posted June 1, 2013 I still may or may not block these for more height. After it is put together going to do a test tow of it Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2 Link to comment Share on other sites More sharing options...
Chris Posted June 1, 2013 Author Share Posted June 1, 2013 More goodies arrived Link to comment Share on other sites More sharing options...
SarahsGMC Posted June 2, 2013 Share Posted June 2, 2013 Looks good Link to comment Share on other sites More sharing options...
Chris Posted June 2, 2013 Author Share Posted June 2, 2013 I install the brake controller tomorrow. Monday I will have the bushings pushed out of the 2500HD springs and hangars Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2 Link to comment Share on other sites More sharing options...
LongrangeLauber Posted June 2, 2013 Share Posted June 2, 2013 I install the brake controller tomorrow. Monday I will have the bushings pushed out of the 2500HD springs and hangars Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2 If you have an air hammer that works too, that's how I did mine the first time. Then I acquired my press so that helped when I reinstalled them on my HD springs. Don't forget to put the polyurethane grease on any part of those bushings that contact metal. Those urethane bushings will squeak after a while, I have the same ones. But, the handling is tenfold over rubber bushings Link to comment Share on other sites More sharing options...
Chris Posted June 2, 2013 Author Share Posted June 2, 2013 Where do I get this grease? Link to comment Share on other sites More sharing options...
LongrangeLauber Posted June 2, 2013 Share Posted June 2, 2013 Where do I get this grease? Here's a link to different sizes available. This is like their factory outlet website or something like that. I would suggest you get the 8oz. tub, because you will use it and have some left over. And if you decide to do the front suspension bushings (it is soooo worth it) you will have enough for that as well. http://www.energysuspensionparts.com/Energy-Suspension-Formula-5-Prelube-Bushing-Lube.asp Check your box before you purchase any prelube. I think one of my suspension bushing boxes came with a couple little yellow tubs of it, just barely enough for the job at hand. I think each yellow tub was like 1/2 oz. or something like that Even with 9" of lift and 35's, my truck handles like, if not better, than it was stock. I couldn't imagine how well it would make your truck handle being close to stock height Link to comment Share on other sites More sharing options...
Daryl Z71 Posted June 2, 2013 Share Posted June 2, 2013 Looks 1000x better now than when you got it! Link to comment Share on other sites More sharing options...
