jaslo Posted June 4, 2013 Share Posted June 4, 2013 For those of you that have the older 5.3 V-8, has anybody tried a gas mileage tune from Blackbear? Just wondering if he can help gas mileage any? Link to comment Share on other sites More sharing options...
Chris Posted June 4, 2013 Share Posted June 4, 2013 Taken directly from an email conversation between Justin and I "With a gas engine, there won't be a need for a separate economy and towing tune; your foot determines those results and the tow/haul mode provides the shift patterns needed for towing. Justin" Link to comment Share on other sites More sharing options...
diggerdan11 Posted June 4, 2013 Share Posted June 4, 2013 Any tune will help your MPG's. I saw a 3 mpg increase on the highway in my 2001 Chevy, and about a 2 MPG increase in my SS, im assuming I will see the same 2-3 mpgs when i get the tune for my HD Link to comment Share on other sites More sharing options...
jaslo Posted June 4, 2013 Author Share Posted June 4, 2013 I have tried the lighter foot approach. Hasn't helped my mpg. I already do have a tune in the truck, just wonder if Justin's would be better. I recently got 16 mpg. Link to comment Share on other sites More sharing options...
LongrangeLauber Posted June 4, 2013 Share Posted June 4, 2013 I get 14.5 mpg around town on 9" of lift and 35's. I have to keep it out of overdrive though in order to get that fuel mileage. I think it could be a lot worse without a tune. And I run 87 on a 93 tune. Not sure why it makes a difference, but it is like a 2 mpg difference (worse) if I run 93 Link to comment Share on other sites More sharing options...
Badass69 Posted June 17, 2013 Share Posted June 17, 2013 Tune made zero difference on either of my trucks to fuel economy. In fact I have never owned anything I have tuned that actually increased in mileage after the fact. My mileage is the same, regardless. You guys with LM7's, LQ4's and like should log data with your "93" tune and 87 octane gas. I wouldn't be surprised if you don't see any knock retard. Link to comment Share on other sites More sharing options...
LongrangeLauber Posted June 17, 2013 Share Posted June 17, 2013 Tune made zero difference on either of my trucks to fuel economy. In fact I have never owned anything I have tuned that actually increased in mileage after the fact. My mileage is the same, regardless. You guys with LM7's, LQ4's and like should log data with your "93" tune and 87 octane gas. I wouldn't be surprised if you don't see any knock retard. I do get a couple misfires here and there, and a "system too lean" code when it starts to get 90+ degrees outside, but not sure if thats from the improper fuel for the tune, or if its because I never got my ECU reflashed when I did my motor swap from an older (99 into a 02) truck Link to comment Share on other sites More sharing options...
Badass69 Posted June 17, 2013 Share Posted June 17, 2013 I do get a couple misfires here and there, and a "system too lean" code when it starts to get 90+ degrees outside, but not sure if thats from the improper fuel for the tune, or if its because I never got my ECU reflashed when I did my motor swap from an older (99 into a 02) truck Yeah I would look elsewhere than the fuel for either of those. It's just these engines have such a low static compression ratio ( 9.4:1 respectively) that honestly I don't see any reason for it. Misfires and lean codes won't be from detonation. Could be a myriad of things wrong for that..... knock sensors, ve table in the tune, maf sensor etc. The 99 engine has a smaller cam in it than the 02 did and is rated 15 hp less so who knows. Link to comment Share on other sites More sharing options...
LongrangeLauber Posted June 17, 2013 Share Posted June 17, 2013 I felt like I lost power, but everyone kept telling me it was the same. Now I know! Guess I have to upgrade to an LQ9 or LQ4 haha I know they have different heads, between the two motors, but I looked both of the up and they were just numbered differently because they were the same but made by different suppliers. Not sure if this is part of the problem, or if it is solely the cam Link to comment Share on other sites More sharing options...
tyhuck Posted June 17, 2013 Share Posted June 17, 2013 Justin told me that the only way to write a tune for "economy" is to lean out the fuel tables, which is bad for all kinds of stuff, so he wont do it. Link to comment Share on other sites More sharing options...
Badass69 Posted June 17, 2013 Share Posted June 17, 2013 I felt like I lost power, but everyone kept telling me it was the same. Now I know! Guess I have to upgrade to an LQ9 or LQ4 haha I know they have different heads, between the two motors, but I looked both of the up and they were just numbered differently because they were the same but made by different suppliers. Not sure if this is part of the problem, or if it is solely the cam Just the cam really. The injectors I believe are smaller on a 99 too if you reused them.... which could be your fueling issues. Should be either 706 or 862's for heads on either. 6 liters are the way to roll. I own 7 of them total including the 2 in my trucks, lol. Grabbed the last one running fine for $100 with about 130K miles on it ( 2001 LQ4). Cheap and easy. For economy there is the whole lean cruise thing too.... You have fiddle with the PCM's OS to get it to work as it is not run in north america anywhere....... just overseas. In a pickup truck it's going to be probably a waste of time from what I have seen people on the EFILive board get from it. Link to comment Share on other sites More sharing options...
LongrangeLauber Posted June 17, 2013 Share Posted June 17, 2013 I dont remember if I reused the ones off the 02 motor or the 99. I keep saying I wont drop any more cash in this truck, and everytime I say it I go ahead and spend more. That is until I get my Dmax, hopefully... haha Link to comment Share on other sites More sharing options...
Badass69 Posted June 17, 2013 Share Posted June 17, 2013 It's a hobby sickness. Look at the middle truck in my signature, lol. Link to comment Share on other sites More sharing options...
stevo936 Posted July 23, 2013 Share Posted July 23, 2013 I usually drive city and mine went from 15.5 to 16.1 on my 2008 since i got a blackbear tune. It usually depends on your foot too. I picked up .2 mpg since i have had my tonneau cover the last few weeks which is weird. Link to comment Share on other sites More sharing options...
