splash07s Posted July 15, 2013 Share Posted July 15, 2013 When I try to fill up with gas, the pump kicks off every 10-15 seconds, it takes forever to get it full. I am thinking its the vent line but I was also told it could be an evap canister. Will I have to drop the tank to clear all this up? Also, it says I am on empty after only about 20 gallons, I know I have a 26 gallon tank, What up with that? 2004 2500HD 6.0L gas 4X4 Link to comment Share on other sites More sharing options...
Carder09 Posted July 15, 2013 Share Posted July 15, 2013 I guess you have already tried to adjust have far in/out the nozzle goes in? Sometimes that happens and I adjust accordingly. As for the other thing, sounds like a sending unit issue. Link to comment Share on other sites More sharing options...
txab Posted July 15, 2013 Share Posted July 15, 2013 Evap vent Gauge: How long have owned the truck? How long has the problem been active? Could be sending unit or dash gauge (if the cluster has had stepper motors replaced) Link to comment Share on other sites More sharing options...
hodo78 Posted July 15, 2013 Share Posted July 15, 2013 I have had this issue since i purchased my 2012 Sierra 18 months ago, and I also had it happen on my 2010 Sierra. I learned quick that only about half of the pumps I tied will do it. And when you get to a pump that does stop pumping every 10 seconds or so, just pull the spout out about 1 inch and it should correct the problem. Link to comment Share on other sites More sharing options...
splash07s Posted July 18, 2013 Author Share Posted July 18, 2013 its definitely not the pumps im using. The truck has 170K miles and its new to me ao I dont know how long its been going on but I have figured out that there is about 5 gallons left in the tank when the light comes on. I dont know if the stepper motors have been replaces either. Link to comment Share on other sites More sharing options...
splash07s Posted July 18, 2013 Author Share Posted July 18, 2013 what will be the process for clearing the evap vent? drop the tank or lift the bed? hoping neither, expecting both Link to comment Share on other sites More sharing options...
scooby5121 Posted July 19, 2013 Share Posted July 19, 2013 It requires neither, it is accessable (in plain view) Link to comment Share on other sites More sharing options...
txab Posted July 19, 2013 Share Posted July 19, 2013 what will be the process for clearing the evap vent? drop the tank or lift the bed? hoping neither, expecting both http://www.truckmodcentral.com/forums/f63/p0449-how-replace-evap-vent-solenoid-1977/ Link to comment Share on other sites More sharing options...
splash07s Posted July 19, 2013 Author Share Posted July 19, 2013 Ok thanks yall, I also found a cheap replacement part # 25932571 on Amazon for like $15 Link to comment Share on other sites More sharing options...
seasled Posted July 20, 2013 Share Posted July 20, 2013 every truck i have owned is on E too soon!!! lol Link to comment Share on other sites More sharing options...
