I have a 2002 Silverado 2500 with a 6.0L. Does anyone know if a 1500HD or 2500HD hood will fit on the regular 2500 or if the inner components are different? I have been told various different answers and am looking to swap for the raised HD hood.
Share this post
Link to post
Sign in to follow this
  • Similar Content
    • By Texas Suburban Trucker
      I'm wanting to put some nice looking Beadlock wheels on it with some 33-35 inch Tires, for my next upgrade. (220,000 miles so far)
      I would like some advice on what tire would fit while turning full lock to lock without Rubbing. I'm installing the big fender flairs from Bushwacker, that require cutting the fenders, these add 4-5 inches in width. Have a 4 inch lift in front and a 2 inch lift in the rear. (Rancho Suspension lift) I will drive this everyday on and off the farm (tends to get pretty muddy after a rain), as well as on and off road trips. Maybe even some storm chasing.
      I'm leaning towards these wheels:
      ATX SERIES BLACK AX757 CHAMBER PRO II WHEELS 17x9, 8x6.5, with the BF Goodrich KO2 Tires.
      Here is a link with the details. http://www.americanracingequipment.ca/wheel/33130/ax757-chamber-pro-ii
      How big of tire can I put on and NOT have any Rubbing? If the Tire sticks out no big deal the fender flairs will cover tires 4-5 inches outside the fenders.
      If there are better suited wheels AND tires for this Truck feel free to add that information. This is an expensive upgrade especially since the Drivetrain has also been replaced or rebuilt and upgraded.
      Looking for some well thought out honest advice.
      I need to run a Grade 8 Tire as I haul my Tractor for service, and I also want the ability to air down for more traction if necessary. The wheels are 17x9. (See Link Above) I would like a strong, capable long lasting Tire for the duties listed above.
      I will answer any questions you have of me.
      Thanks in advance,
          Quote   Edit
    • By 6.0bigred
      I have a1999 Silverado 2500 4x4 6.0 that I just got running again it has been sitting for 2 years because my girls dad was going through some rough time and didn't really care now 2 years later he is in no shape to be under a hood or on his back messing with the thing anyways I needed a vehicle and he said if I could get it running I could use it I went and bought a can of sea foam a 10gal gas can with gas and battery put everything in/on and it started right up like it was nothing I was like sweet since then witch was 2 days before this post ive don a oil change wit 10w30 Castrol edge high millage and k&n oil filter a much needed bath all new lights toped off dexcool, power steering,  witch is leaking but the whole reason I was making this post was when I stop at nights 2 things happen AND ONLY SOMTIMES the gas peddles feels like its getting stuck when I go to APPLY presser but not on release  and it idles funny but if I put it in natural and rev it the put it back in gear it will idle normal the rest of the time till the light turns green but at the next light it may or may not do it what do you think it could be
    • By bronyaur
      I recently inherited a 2002 Silverado 1500 Standard cab 4.8L 4x4 manual NV3500 transmission.  It has 208k miles on it.  My oldest son is 14 and we plan to restore it so he'll have something to drive when he gets his license.  It drives very nicely.  There's some slop in the front end and I expect it's due a pitman and idler arm, ball joints, and probably tie rod ends.  Aside from that, the only thing that concerns me is shifting from 2nd to 3rd.  It's really hard to find 3rd gear, and when I do it takes a little force to get it in there.  Downshifting from 4th to 3rd is smooth.  Any ideas as to the cause and fix?
    • By Blackflag8
      Hey what's up everyone. Not sure if this is where to ask this or not.  I'm looking to upgrade from a chevy 2002 1500 z71 to a 2500 chevy or gmc I've been looking from about 2004 and up. The biggest issue I'm trying to decide right now is gas or diesel. I am a mechanic but never worked or messed with diesels.
      So I tow a open car trailer and racecar in the summer during race season right now about 6,000-7,000lbs depending on which car is on it. I do tow some other stuff here and there too. But I would like the ability to tow more and to have something better for long distance trips and driving/ towing in the mountains. Now mountain trips would probably be less then a handful of times a year. Unless we really decided we liked racing at the track out there then might go a few more times. I don't plan for the truck to be a daily driver. I've put about 20,000 on my 1500 I have now in the 8 years I've had it. About 2-3 years of that was daily driving. Now whatever I do get I plan on having for a good while probably at least 10+ years I would say.  And also want to be prepared if I ever upgrade to an enclosed trailer or ever got a camper etc..
      What I do know right now is 6.0 is a gas hog, Duramax will give you better fuel economy and obviously better when it comes to towing. I know  Lbz trucks seem to be the ones everyone says are the best to go for. But I don't know if I do enough hauling to justify the added expenses and maintenance for a Duramax.
      Also just trying to figure out what the best years, engine, and trans combos are to look for and any other issues either of these trucks have to be aware of. Sorry if this was too big of a post or not the right place to put this but Any advice help or opinions are greatly appreciated.
    • By Zane
      Zane Merva
      Executive Editor, GM-Trucks.com
      3/16/18
      General Motors is hard at work testing the next generation of Heavy-Duty Silverado and Sierra pickups.  The 2020 model has recently been undergoing cold weather testing, which is really no surprise as it's "winter" in North America right now. Our Spy Photographer recently put together a HUGE 46 image MEGA SET of 2020 Silverado HD photos. We just had to share.
      Here's what our photographer says:
      2020 GM HD Chassis Cab Shows New DEF Tank Placement
      Our first look a the 2020 GM HD Chassis Cab flatbed gives us a nice peek underneath, giving some new details of the rear suspension set-up, and the positioning of the DEF tank for the Duramax diesel.  The DEF tank on the current Duramax diesels from GM is mounted quite low—and very visibly—on the front passenger side of the frame.  The massive tank’s placement has been oft-criticised by diesel fans, as awkward and ugly.  The DEF tank placement on 2020 HD Diesel trucks has changed—as revealed in our profile shot of the chassis cab prototype.  The new DEF tank now appears to reside close to the DEF additive cap, on the driver’s side behind the rear wall of the regular cab.
      2020 GM HD Regular Cab Work Truck
      This Regular Cab/Long Box prototype shows the next-gen Chevy HD in its most work-focused form.  The Regular Cab HD prototype, caught in these latest spy shots, gets the long eight-foot bed design, for the most versatile payload possibilities.  GM touted new stamping methods which reportedly increased the usable bed width by 7-inches on the 2019 Chevy Silverado, so it’s likely we’ll see a similar gain in bed capacity on these HD models.  If that’s the case, this gargantuan long-bed option will be even more voluminous, making it ready to handle an even larger work load.
      This Regular Cab prototype was gasoline-powered, so we’re likely looking at the 2020 version of what is now powered by a 6.0-liter Vortec V8 engine.  It’s safe to assume that the gas powerplant under this HD’s hood is utilizing new
      Dynamic Skip Fire (DSF) technology to enhance the cylinder cut-off performance.  DSF technology finally bowed in some versions of the 2019 Silverado, and it’s a certainty that it will be part of the 2020 HD mpg-enhancing tricks.
      2020 Duramax Crew Cab
      Our latest shots of the 2020 HD Duramax Crew Cab—which provide some of our closest, most-detailed look yet at new HD trucks—were caught as the prototype made a lap around the GM Proving Grounds.  A close look at the camouflage on the at the center of the front edge of the hood reveals a mesh panel that will allow air to enter into the Ram Air slot hidden on the hood.  The Ram Air hood scoop was added to GM’s HD trucks in the last update, and they’re said to feed up to 60% of the cooling air required by the engine, increasing horsepower and torque.  The camouflage mesh panel has velcro taps at the front and back, which would clearly allow for the panel to be folded back and secured to allow more air-flow, as testing permits.
      The exhaust tips are consistent with prior GM HD diesel trucks, and it looks like we can see evidence of venturi air slits along the initial span of the exhaust pipe.
      The new shots give us our best look yet the massive grille that appears to be in store for GM’s next-gen HD trucks.
      A deep dive into the specs of the recently-unveiled 2019 Silverado 1500 revealed some of the tricks that are also likely destined for the HD truck.  The camouflage hides any evidence of Silverado 1500’s innovative front fascia aerodynamic air curtains, but that’s not surprising, since that design revelation made it all the way to its debut without being leaked.  Expect the same stamping, and packaging innovations that debuted on the 2019 models to translate to the HD models, for increased bed space and cabin space.  It’s clear from these prototypes that GM’s next-gen HD pickups will be massive beasts to match the Ford Super Duty.
      2020 GM HD 3500 Dually Crew Cab
      We’ve included our earlier shots of the HD Dually prototype that originally signaled the start of testing for GM’s 2020 HD pickups.  The Crew Cab Dually is a massive thing, impressive in size, and amplified by what appears to be a more larger grille destined for GM's next-gen HD trucks.
      The prototype’s caught here appear to the Chevy Silverado HD variants, with judging by the horizontal nature of the placeholder LED signatures that are in visible through the frontal camouflage.
    No registered users viewing this page.
    Readingbabelfish
    Readingbabelfish
  • Who's Online   108 Members, 0 Anonymous, 327 Guests (See full list)
