Oil filters
36 replies to this topic
#16 2014 Sporty Shorty
2014 Sporty Shorty
  • Member
  • 201 posts
  • Name:Will
  • Drives:2014 SLE single cab short box
Posted 27 October 2013 - 09:25 PM
I have heard of not only GM but Ford try to cancel warranty because my neighbor used Fram filters on his 2013 F150 ecojunk. His motor took a dump with 17000 kms on it and the dealer tried to deny warranty because they couldn't prove when he did the oil change  and he was using a "well known" filter for letting filter media escape into the engine. It's been almost a month and a half and they still haven't fixed his truck.
I'm not spoiled, it's called a job
#17 clayp
clayp
  • Member
  • 176 posts
  • Gender:Male
  • Drives:2014 GMC Sierra SLE crew std bed 4x4
Posted 30 November 2013 - 09:59 AM
just FYI most auto parts stores and even the AC Delco website don't have the updated info for the 2014 trucks yet. I went to my dealership and ordered two filters and they are the AC Delco PF63
2001 Silverado ECSB Z71 4x4 6.0l swap
2012 Suburban Z71 4x4
2014 Sierra CC std bed 4x4 SLE
#18 suess13
suess13
  • Member
  • 101 posts
  • Name:bill harvey
Posted 22 December 2013 - 07:57 AM
Oil Filter with Incorrect Label
Some early 2014 Corvette 6 .2L engines (RPO LT1) may have an oil filter that has an incorrect label on the can . The filter is correct, only the label is wrong .
The incorrect
label says to
replace the oil
filter with a PF63 filter . The correct service part is a PF64 filter, part number 12640445 . Replacement of the filter for the incorrect label is not necessary .
When it is time for an engine oil and filter change, be sure to replace the OE filter with the correct PF64 filter .
TIP: The PF63 filter will fit the engine . However, it is significantly longer and it is pos- sible it could be damaged if the suspension goes to full compression .
Thanks to Richard Renshaw
#19 davis1
davis1
  • Member
  • 325 posts
  • Gender:Not Telling
Posted 22 December 2013 - 08:20 AM
I had a toyota pick up back in the '80's Changed my oil every 3000 miles my self. Kept all the receipts. The motor blew up,it was determined a bad piston rod was the cause by an arbitration mechanic. At 22,000 miles Toyota would not cover it because I could not prove the changes actually happened. Even though there was no other signs of abuse or neglect on the engine internals. So now I spend the money for the dealer or other place that can document the work. Cost me $2700 for the new motor
#20 clayp
clayp
  • Member
  • 176 posts
  • Gender:Male
Posted 22 December 2013 - 08:24 AM
The incorrect
label says to
replace the oil
Are you sure this applies to our trucks? I cannot imagine the ground clearance for the oil filter is going to be an issue on a truck, whereas it is very relevant on a Corvette
#21 diannabill
diannabill
    diannabill
  • Member
  • 490 posts
  • Name:Bill
  • Gender:Male
  • Drives:2014 Silverado 4WD 1500 LT DBL, All Star
Posted 22 December 2013 - 08:35 AM
I keep accurate record of changes and I've always kept every receipt.  I can at least prove that I purchased the oil and filter at some point prior to when I'm claiming I changed it.  Now if they want to say I was just buying stuff that I never used I guess they can, but that's a ridiculous claim.  And I'm sure they can tell when the Oil Life Indicator was reset, which I plan to do at each change.  It would be difficult to try to say that it was all faked by me.
As to oil filters - I've used Fram filters exclusively on all of my vehicles for quite awhile.  Maybe I got lucky, but one of the simple advantages of Fram is that it has a sandpaper type grit area on the end that allows you to install it and remove it by hand without any filter wrenches.
I'll have to do a little more research on oil filters though.  But I did make it a point to check with Honda for my wife's vehicle, and they said it would in no way violate the warranty if I used a filter other than Honda's.
I do plan on trusting my dealer for the first 24 months, but I'd never trust anyplace else (like Jiffy Lube).
Edited by diannabill, 22 December 2013 - 08:37 AM.
#22 diannabill
diannabill
    diannabill
  • Member
  • 490 posts
  • Name:Bill
  • Gender:Male
Posted 22 December 2013 - 08:41 AM
What "well known filter" are you referring to?
#23 RyanbabZ71
RyanbabZ71
    Administrator
  • Moderator
  • 22,844 posts
  • Name:Ryan
  • Gender:Male
  • Drives:2010 Chevy Silverado Crewcab Z71 6.2L
Posted 22 December 2013 - 09:40 AM
I take photos when I do mine.
Ryan
Ryan
2010 Silverado Crewcab 4wd Z71 6.2L V-8 (L9H) Flex Fuel 6 Speed Transmission Sheer Silver Metallic
2012 Camaro 2SS Convertible 6.2L V-8 (L99) Ashen Gray Metallic
My Build: http://www.gm-trucks...do-z71-crewcab/
Camaro Mods http://www.camaro5.c...ad.php?t=257256
#24 diannabill
diannabill
    diannabill
  • Member
  • 490 posts
  • Name:Bill
  • Gender:Male
Posted 22 December 2013 - 10:13 AM
I take photos when I do mine. Ryan
Do you keep a photo album?  "Baby's First Oil Change"  etc ?
What do you take the photos of?
#25 RyanbabZ71
RyanbabZ71
    Administrator
  • Moderator
  • 22,844 posts
  • Name:Ryan
  • Gender:Male
Posted 22 December 2013 - 10:26 AM
Oil and filter used. Magnetic drain plug, mileage Just keep it in a hard drive. Takes maybe 30 seconds to snap photos Ryan
Ryan
#26 STex
STex
    Senior Enthusiast
  • Member
  • 1,381 posts
  • Gender:Male
  • Drives:09 SLT CC 4x4
Posted 22 December 2013 - 01:45 PM
I was using M-! oil filters but switched back to OEM. Because on one trip for oil change, I saw a torn down 5.3 in an SLT.  The engine had failed due to oil starvation in some area due to oil filter media in the engine. It was a non-oem filter and they were waiting on GM to ok the repair. The discussion of warranty denial was part of the conversation.
So yes we know  they will not dump your warranty for using fram or some other filter, BUT if engine does fail due to oil filter issue I would rather not have the conversation. Thus OEM oil filter and no conversations.
#27 diannabill
diannabill
    diannabill
  • Member
  • 490 posts
  • Name:Bill
  • Gender:Male
Posted 22 December 2013 - 02:57 PM
Now I'm wondering if there is possibly more danger of oil filter failure nowadays than there used to.  Used to change oil and filter at 3,000 miles.  Now you can go upwards of 7,500 miles (or more?).
I've always changed it at 3,000 miles until my wife's 2010 Honda CRV with synthetic oil and I change it at 5,000 miles.  Possibly some filters can't go that long without material breakdown?
Yes, I think I'm beginning to agree if spending more for an OEM filter from the Chevy parts department might be a good idea.  Wonder how much more they cost? (Probably not as much as a new engine lol)
Edited by diannabill, 22 December 2013 - 02:58 PM.
#28 RyanbabZ71
RyanbabZ71
    Administrator
  • Moderator
  • 22,844 posts
  • Name:Ryan
  • Gender:Male
Posted 22 December 2013 - 03:08 PM
I buy the ac delco filters in bulk. 12 in a case usually $40-50 Ryan
Ryan
#29 pm26
pm26
    Senior Enthusiast
  • Member
  • 7,409 posts
  • Gender:Male
Posted 22 December 2013 - 04:52 PM
You are always better off using GM Delco filter.  Here is why.  Supposing the filter somehow splits open, dumps the oil and ruins your engine.  If it is a GM made filter they will most likely pay for a new engine even if the vehicle is out of warranty since it is the GM part that caused the failure.  If some other make filter causes it, good luck fighting with the filter manufacturer to buy you a new engine.
#30 spx1000
spx1000
  • Member
  • 225 posts
  • Gender:Male
  • Drives:Anything FAST!!!!!!!
Posted 24 December 2013 - 09:51 AM
So is it a PF63 or PF64?
2017' GMC Sierra SLT, RC 2.5" Lift, Extang Trifecta Cover, LED's everywhere...for now....
2014' GMC Sierra SLT, RC 2.5" Lift, GY DuraTrac 275/65/20's, Extang Trifecta Cover, TRS HID's, Vled Fog's, LED's everywhere...
Reply to this topic
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
