- 0
2007 Avalanche Low Oil Pressure at Idle
Similar Content
transfer case 2015 GMC Sierra NQH transfer case stuck in neutral.
By Detroit Diesel,
- transfercase
- Nqh
- (and 7 more)
- 0 answers
- 111 views
Silverado 2021 Custom Trailboss 5.3 problems and questions
By Rob Paul,
- 2021 Silverado 1500
- Trailboss
- (and 1 more)
- 7 replies
- 960 views
- 4 replies
- 1,882 views
- 8 replies
- 2,799 views
- 3 replies
- 2,971 views
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 18 Members, 0 Anonymous, 1,801 Guests (See full list)
Question
jhall0828
The oil pressure on my 2007 Avalanche with 108k miles (LC9 Flex Fuel 5.3L with AFM) is low at hot idle (less than 20 psi per dash guage). It comes back up just off idle, but even at highway speeds is only hovers around 45-50 psi. Previous history on the truck is at 80k miles I had the AFM Oil Pressure Relief Valve Deflector installed due to oil consumption and oil fouled plugs on AFM cylinders. At 90K miles, I had the cam, lifters, push rods, rocker arms, etc. replaced due to knocking on cold start along with continued high oil consumption. I noticed the lower idle oil pressure after getting the truck back after the cam, etc, replacement. The oil consumption has remained higher than what I would expect, and recently I had an extremely rough idle/miss. I pulled the #1 plug and the insulator was cracked and oil appeared to be leaking through the plug. Any thoughts on what problems may be contributing to the low oil pressure, oil consumption, etc.?
1 answer to this question
