Sign in to follow this
ChevMech
Electric Winch Connection
I recently purchased a 2009 Silverado 2500 HD LTZ with a 6.0. She's pretty and fun to drive, but I plan on putting her to work.
That being said, I have a 20 ft bumper pull with a 9,000 lb electric winch on the front to move vehicles. Thus far I have just had a battery connected to the winch and would charge it when needed. It has proven a little inefficient.
What I'm thinking is I'm going to run a cable from positive side of the battery to the back bumper with a plug to connect it to the winch. Will this hurt the trucks electrical system in any way? Where would be the best place to run the cable from? I'm planning on putting a master kill on the cable just for safety.
Share this post
Link to post
Do it right and run a circuit breaker, heavy enough cables, and a quick plug in connector. Should not hurt electrical system if done right.
Sent from my LGL86C using Tapatalk
Share this post
Link to post
I used the warn quick disconnect http://www.warn.com/truck/accessories/quick_connect_all.shtml
warn power interrupt kit http://www.warn.com/truck/accessories/power_interrupt.shtml
routed it around fuse box
down inner fender and along frame with body harness to quick disconnect
also power winch up front
for additional quick disconnects for jumper cables and what not buy the from Anderson Power Products http://www.powerwerx.com/anderson-powerpoles/powerpole-sets/sb175-sb-series-175-amp.html and borrow or buy the hydraulic crimp harbor freight http://www.harborfreight.com/hydraulic-wire-crimping-tool-66150.html
Edited by hzhardy
Share this post
Link to post
Thanks for all the information. I bought the quick connects awhile back, but never got the cable.
Where can you find good battery cable at a decent price? My local auto parts store wanted like $5 a foot for the stuff, so the project got put on hold temporarily. If that's the going rate, I'm just going to have to take the plunge, so to speak.
Share this post
Link to post
My buddy runs a pair of battery and they just charge off thr aux power on the 7 pin
Sent from my SCH-I535 using Tapatalk
Share this post
Link to post
Quality cable is expensive. And don't skimp on something as high power as a winch.
Share this post
Link to post
