- 0
Runs fine, Parked, 1 hour later, Starter will not engage.
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 22 Members, 0 Anonymous, 1,954 Guests (See full list)
Question
wjs1500
2005 Silverado Extended Cab, 70k miles. Starts fine, runs for about 45 min to hour, parks, waits about an hour to go shoppine etc., when try to start the starter will not engage at ALL. All lights are on the dash, the headlights dim when the key is turned (assume that is normal to reduce battery drain - my motorcycle does the same), If i wait about 45 min to an hour and try it again the truck starts.
Highly intermittant. The last time it happened I had it towed to a repair shop. Once I got it off the tow truck it started. The shop played with it for a week and could not duplicate. Did all the normal things (swap relays etc.).
Now here is the kicker that may help. Last night I drove home and backed into the driveway to load some stuff. Shut off engine. Came back out after loading and would not start. Went into the house, said a few not so pleasant words and started searching the internet for some help. Went back out half hour later still not start. Searched some more. One guy said it might be the door unock system or something related. So when I went back out another half hour later cycled the remote door lock 5-6 times, opened and closed the door 2-3 times and it started. Drove the truck in the garage and there it sits.
One other thought. I seems to happen when the truck is backed up before shutting down. If I pull into a parking spot in drive it seems to start normally. In case you are wondering I have tried it in Park and Neutral and cycled the shift lever extensively. HELP. And the Battery is BRAND NEW (1/10/14) a warranty replacement for a 1/21/13 battery.
5 answers to this question
