- 0
01 silverado 3500hd 8.1 studder/low power
Recently Browsing 0 members
245.8k
Total Topics2.6m
Who's Online 20 Members, 2 Anonymous, 1,975 Guests (See full list)
Question
treehugginhippi
Hi, this is my first post on here but I have done a search and have gone through many steps to correct the problem before I made my account.
So here we go the truck is a 2001 Silverado 3500hd 8.1l 5spd cab and chassis.
It seems to have 3 dead holes for no apparent reason.
A bit of back story. I am the mechanic for a plumbing company in Kansas City, we have 32 04-12 Chevy express 3500 6.0, 6 04-06 Silverado 3500, and 3 of these 8.1turds 2 of which run perfect and this one.
Symptoms:
runs rough has a bad studder/miss low power and it takes full throttle to keep it going 70mph.
What I have done:
As I said I have read through lots of your previous posts and have exhausted all of my knowledge and patience.
I have replaced/swapped parts from our other trucks... Those parts are,
throttle body
egr valve
map sensor
maf sensor
evap purge sol
ckp sensor
Exhaust/to rule out cats
all 8 spark plugs
all plug wires
Fuel rail
fuel pressure regulator
all 8 injectors
I also tested fuel pressure... With my scanner running the pump constant it sits at 55-57psi at idle it sits at 46-48psi and spikes back to 55ish with full throttle.
Tested coil resistance and all 8 are within spec. Also put a spark tester in and all 8 have same looking spark
ran a compression test:
1) 160
2) 158
3) 160
4) 160
5) 165
6) 165
7) 165
8) 170
this truck of the three we have had the lowest mileage @195k and also has the best care/driver.
With my scanner I shut off injectors one at a time, all changed engine tone and made the studder worse except number 2,4,7 which didnt sem to change anything. Injector test was done at 1500rpm.
Any help would be greatly appreciated.
2 answers to this question
