- 0
Buick Century TCC Fault Code
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 23 Members, 0 Anonymous, 2,030 Guests (See full list)
Question
Jetmechof7s
Hi,
I have a 1994 Buick Century with a TCC issue. The car has only about 74,000 miles on it, and is in great shape.
After about 40 minutes of driving, the car drops out of Overdrive, and the TCC drops out too. This occurs on level roadway, with no additional throttle demand.
Once this happens, it'll never go into Overdrive again, until I shut the engine down, and restart (I can do that while it's rolling, or stop first). After that, the P0740 (TCC Circuit Malfunction) code will be gone from the current faults, and the car will go back into Overdrive (The fault code will remain in the history). Usually within a minute or two, it'll fault again, and drop back into Third Gear. Once it has totally cooled (such as while I'm at work, or over-night), I'm good for about 40 minutes, before it happens again.
The car had been sitting alot and the hydraulic fluid was a little dirty, so I had it flushed, hoping it would go away. No such luck.
Does anyone have any ideas?
-Maybe just a weak solenoid valve that gets hot and won't hold anymore? It never fails to engage initially, when I first get to the highway. It really does take about 40 minutes, to happen. I find it odd, that once it does, it won't go into Overdrive again, even for hours! -but it will after it totally cools down.
If that's it, how hard is this to change, and how expensive? Do I have to remove the torque converter, trans, or anything else?
Thanks!
Patrick
15 answers to this question
