Jasonsupafly Posted July 29, 2014 Share Posted July 29, 2014 Sup, guys! Been a while. Just received my dual 10 SubThump box for my 01 extended cab. Air space for each side is .70. Anyone have any idea of decent subs with this little space? Also what would be a decent amp to go with to power 2 10's? Not looking to shake the truck apart but would like it to sound as good as possible with the space I have with this box. Any help is greatly appreciated! Link to comment Share on other sites More sharing options...
hodges25 Posted July 30, 2014 Share Posted July 30, 2014 Jl w1v3 or w3v3 depending on your mounting depth Link to comment Share on other sites More sharing options...
Jasonsupafly Posted July 30, 2014 Author Share Posted July 30, 2014 Thank you, sir. I will check them out. Mounting depth is 6.5". Link to comment Share on other sites More sharing options...
99k1500 Posted August 1, 2014 Share Posted August 1, 2014 My next sub will be a sundown SA-10 Link to comment Share on other sites More sharing options...
ericpdadof3 Posted August 27, 2014 Share Posted August 27, 2014 If you are on a budget, the Rockford Fosgate R2D2-10 is a good speaker. The JLs are pretty high end, and the Sundowns are mostly SPL subs. The R2D2 is a dual 2Ohm sub, so you can run them at 2 Ohms mono for both subs. At 250 watts RMS each, you can get a nice mono block amp. The Rockford Fosgate R500X1D would be a good match. It will put out 500 watts mono at 2 Ohms. This setup would only cost you about $250 for the subs and amp, and would put out quite a lot of bass. You can always go more expensive, but this would work with your box setup very well. Link to comment Share on other sites More sharing options...
WhineyTTwins Posted October 6, 2014 Share Posted October 6, 2014 Image Dynamic subs for that tight of an airspace. Cant go wrong with them. been running ID subs for 4 years now and don't go anywhere else for SQ and as far as an amp, Sundown amps are great. Currently running the SAZ-1200D Link to comment Share on other sites More sharing options...
