RCP Posted August 1, 2014 Share Posted August 1, 2014 This problem started as an intermittent thing and has progressively gotten worse and worse. It primarily hapens upon turning (right or left make no difference). I thought it was perhaps the wheel bearings so I replaced the wheel bearing assemblies on both sides yet the problem persist. Anyways, not sure where to try next. Any help would be appreciated! Truck is a 09 Silverado 1500 with approx. 105k on it and is a 2WD. Link to comment Share on other sites More sharing options...
Beer Belly Posted August 1, 2014 Share Posted August 1, 2014 could it be something rubbing ?? Link to comment Share on other sites More sharing options...
RCP Posted August 1, 2014 Author Share Posted August 1, 2014 Don't think so when I originally started looking I jacked it up, turned the wheels both ways and spun the wheels and could not find it rubbing on anything. However, there is no noise when the suspension is unloaded (or on a jack) making it hard to locate. After its let back down and the weight of the truck is on it the noise is back. Link to comment Share on other sites More sharing options...
DaveH71 Posted August 1, 2014 Share Posted August 1, 2014 What do your brakes look like? Pay attention to the inside pad especially, and check the dust shields for proper clearance from the rotors. Link to comment Share on other sites More sharing options...
RCP Posted August 1, 2014 Author Share Posted August 1, 2014 I replaced the front brake pads when I replaced the wheel bearings Link to comment Share on other sites More sharing options...
txab Posted August 1, 2014 Share Posted August 1, 2014 Do as Dave suggested, check dust shield clearance next Link to comment Share on other sites More sharing options...
