yfzrider Posted November 22, 2014 Share Posted November 22, 2014 Currently have a 2013 silverado with the 2" RC leveling kit and running 275-70-18. Tires are shot and looking to go with 285-70-18 tires what are my options suspension wise to be able to clear them. Link to comment Share on other sites More sharing options...
TooTall1 Posted November 22, 2014 Share Posted November 22, 2014 I have LT285-70-17 tires on my 2008 with a 2" level with no issues. You should be fine. Link to comment Share on other sites More sharing options...
Big Whiskey Posted November 24, 2014 Share Posted November 24, 2014 Currently have a 2013 silverado with the 2" RC leveling kit and running 275-70-18. Tires are shot and looking to go with 285-70-18 tires what are my options suspension wise to be able to clear them. Well, since you already have the 2" leveling kit, the next step would be a 4" lift kit...which is a pretty expensive step to just bump up 1" in tire height. I'd look into the 1.25"-1.5" body lift option. Our trucks hide those really well. Or, just keep it like it is now, and trim as needed. I've seen 285/70/18's on the stock rims with a 2" or 2.5" level, so your rims are the only thing holding you back. It shouldn't take too much trimming to make them fit. I have LT285-70-17 tires on my 2008 with a 2" level with no issues. You should be fine. Yes, but he's looking into a 285/70/18...which is 1" taller than your tires. Plus, he has aftermarket rims, which make it even more difficult to fit larger tires. Link to comment Share on other sites More sharing options...
durandetto Posted February 4, 2015 Share Posted February 4, 2015 I would add a block to the rear and a 1/2" spacer between the strut and lower control arm. I've done lift/ level kits with 2.8" in front and 1" in rear. Might still need to trim some plastic though. Sent from my LGLS990 using Tapatalk Link to comment Share on other sites More sharing options...
