- 0
Bad idle after replacing battery
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 3 Members, 0 Anonymous, 590 Guests (See full list)
Question
91710zx10
2000 GMC with 6.0 with 135k miles. Replaced the battery recently and thats when the problems started. It ran perfect before the new battery. Yes I've searched and learned what my problem could be which is the computer reset and has to learn new idle I've ran 2 can of seafoam in gas tank one with full tank and second can in there now with only 1/8 tank of gas. Also seafoamed the throttle body with entire can of seafoam. Also pulled out MAF and cleaned with MAF cleaner. Pulled intake tubeing off and sprayed and cleaned throttle body best I could with tooth brush and wiping clean with rags and yes they were coming out black. (I've since learned how to remove the throttle body and will do that next and super clean it) I am running a K&N filter which I've also cleaned and oiled when I cleaned MAF. New Plugs and fuel filter done at 100k miles. So after all the cleaning it idles good now, BUT there is slight struggle once you give it gas which was never there before. Also had a flashing check engine light come on for about 1 minute then turned off. Now that things are clean should I disconnect the battery again for a few hours then drive around again? This truck is not my daily driver but I can drive it more if thats whats needed to help computer re-learn. What am I missing or doing wrong?
5 answers to this question
