Lube points
Can someone tell me, or better yet pictures, where the lube points are under the truck.  I seem to remember reading some where that there are 6 points.  True?  Where are they?  Thanks.  Any particular type I should use?
I've got 11 on mine.
4 total for upper and lower ball joints
2 for outer tie rod ends
2 for inner tie rod ends
1 for pitman arm (I think it's the pitman arm.  Pass side tight spot)
2 for I can't remember where off the top of my head.
Hope it gets you started at least.
There is a great site floating around here somewhere with good pics, I just dont have it right now but I am sure someone will post it soon. There are actually 11 I think, 3 in each wheel, 2 on two little arms going out, and 3 more under the skid plate that can be tricky to get to, but arent too bad with a long hose.
  • 3 years later...
Okay, so I've been searching the forums for a while with no luck finding a howto and pictures for a newb wanting to do his own lube jobs. This was the most promising thread so far that I've found but the link is dead! :cheers:
There are eleven. The link above (Tech article) does a good job of showing you where they are. Make sure you find all eleven; some are very hard to get to.
My dealer and their mechanics told me there were only ten. Totally wrong. I have a 2000 Suburban 1500 2wd.
