rutwad Posted May 3, 2015 Share Posted May 3, 2015 I have a 2011 Silverado Crew with 265/65R18 on stock wheels. I am going to install a CCM 2.5" front/0.75" rear kit. If I keep the factory wheels, what size tire will fit without any rubbing? If I buy new wheels, what size do I need? I see a lot of mention as to offset, backspacing, etc. It's all new to me. Thanks in advance!! Link to comment Share on other sites More sharing options...
Big Whiskey Posted May 5, 2015 Share Posted May 5, 2015 A 275/70/18 is a very common size on our body style of trucks with a leveling kit...and they're cheap. You could also run a 285/65/18, but they're more expensive. Some guys also run a 305/60/18, but they're not as common. If you buy aftermarket rims, I'd go with a 18x9, and keep your offset positive. Factory offset is +31mm. The higher the offset, the more your rims will be tucked inside the fenders...and the more options you'll have for larger tires. Mine are 18x9 with +18 offset, and they sit right about the edge of the fenders. Link to comment Share on other sites More sharing options...
