henrypbui Posted May 22, 2015 Share Posted May 22, 2015 I have a 20ft wood deck dove tail and will be towing a 94 toyota supra that should weigh right around 5000lbs or less with my 5.3 crew regular bed. How much gain should i put on the trailer brake controller? With the empty trailer running a +2 does that sound right or should i drop it down to 0? I am going from Oklahoma City, OK to Charlotte, NC. Thanks in advanced. Link to comment Share on other sites More sharing options...
z71 chevy Posted May 22, 2015 Share Posted May 22, 2015 I have a 20ft wood deck dove tail and will be towing a 94 toyota supra that should weigh right around 5000lbs or less with my 5.3 crew regular bed. How much gain should i put on the trailer brake controller? With the empty trailer running a +2 does that sound right or should i drop it down to 0? I am going from Oklahoma City, OK to Charlotte, NC. Thanks in advanced. I normally hook everything up and go a few mph down the driveway or empty road and apply just the trailer brakes until it pretty much stops the truck just make sure it isn't locking up the trailer tires you will need more gain with the loaded trailer so readjust once loaded Link to comment Share on other sites More sharing options...
bboyce536 Posted May 22, 2015 Share Posted May 22, 2015 Read up on how to do a pinch test. Do one when your empty then again once you're loaded. Link to comment Share on other sites More sharing options...
OmniGLH Posted May 22, 2015 Share Posted May 22, 2015 I followed a youtube video on how to set the gain. It resulted in pretty might right on the same setting as I did initially by feel (before I discovered the YT video). For reference... I have the gain set to 0.5 when my trailer is empty. When I've got my car on it, it's set to 6.5. Trailer is a ~1200# RnR 18' open. Car is a ~3000lb Porsche 944 Turbo. Note that each trailer will also be a little more or less sensitive. Don't take my settings for gold. Link to comment Share on other sites More sharing options...
hurricanoday Posted May 22, 2015 Share Posted May 22, 2015 Great info, gonna be using it when I tow this weekend. Haven't researched yet, but have zero idea how to adjust the trailer brake. Should help a lot Link to comment Share on other sites More sharing options...
thewhitestallion Posted May 23, 2015 Share Posted May 23, 2015 everyone else has hinted or indirectly said it but all you have to do is hook the trailer up and go to a parking lot or empty road and get your speed to about 10-15 mph, does not have to be very fast and apply full brakes to the trailer (by full brakes I mean squeeze the trailer brake controller controls together) until you fell the trailer stopping the truck. if the tires lock up you have the gain too high. you want as much braking power from the trailer as you can get without locking up the tires. with a 5000# trailer set up I would imagine your brake gain will prob be around 7-8, but that really just depends on the trailer brakes. it's not hard, don't think too much about it. Link to comment Share on other sites More sharing options...
volrus Posted April 27, 2016 Share Posted April 27, 2016 Looking for some help. When pulling my 6k lb unloaded camper I have it set to a gain of 10 (max) and the tires still won't lock up. Is something wrong? Link to comment Share on other sites More sharing options...
mjoekingz28 Posted April 27, 2016 Share Posted April 27, 2016 Thanks for the video OmniGLH! volrus, according to the video, what you describe sounds normal. Link to comment Share on other sites More sharing options...
redwngr Posted April 27, 2016 Share Posted April 27, 2016 Looking for some help. When pulling my 6k lb unloaded camper I have it set to a gain of 10 (max) and the tires still won't lock up. Is something wrong? Are the connections in the truck and trailer plug clean? Are you trying the brakes by using the hand operated control? (if not, try it) Might be time to check the brakes on the trailer. Link to comment Share on other sites More sharing options...
HawkeyeSierra Posted April 27, 2016 Share Posted April 27, 2016 Looking for some help. When pulling my 6k lb unloaded camper I have it set to a gain of 10 (max) and the tires still won't lock up. Is something wrong? Not a towing expert by any means, I don't think a 10,000 lb trailer needs to be able to lock the brakes. Link to comment Share on other sites More sharing options...
HawkeyeSierra Posted April 27, 2016 Share Posted April 27, 2016 x2 post. delete, nvm Link to comment Share on other sites More sharing options...
1300c Posted April 28, 2016 Share Posted April 28, 2016 It's also important to make sure that your trailer brakes are adjusted properly on your trailer too. Link to comment Share on other sites More sharing options...
volrus Posted April 28, 2016 Share Posted April 28, 2016 It isn't a 10,000 pound trailer, 6100 dry weight. 7700 max loaded. The camper is brand new, just picked it up yesterday. Doesn't mean it's adjusted properly, but just saying that I doubt that's the issue. I had a 3,000 pound pop up camper and I had to have it on 8 gain to get it to lock up. When we pulled it with my wife's minivan, I could easily get them to lock up. Yes, using the hand operated control to test it at about 20 mph. Link to comment Share on other sites More sharing options...
SouthpawHD Posted April 28, 2016 Share Posted April 28, 2016 Looking for some help. When pulling my 6k lb unloaded camper I have it set to a gain of 10 (max) and the tires still won't lock up. Is something wrong? Sounds like you need to adjust your trailer brakes. Perhaps the pads are worn or something. Link to comment Share on other sites More sharing options...
Jon A Posted April 28, 2016 Share Posted April 28, 2016 It isn't a 10,000 pound trailer, 6100 dry weight. 7700 max loaded. The camper is brand new, just picked it up yesterday. Doesn't mean it's adjusted properly, but just saying that I doubt that's the issue. I had a 3,000 pound pop up camper and I had to have it on 8 gain to get it to lock up. When we pulled it with my wife's minivan, I could easily get them to lock up. Yes, using the hand operated control to test it at about 20 mph. Are you saying you pulled this trailer with your minivan and it would lock them up? If so, there may be an issue. You might want to check the voltage going to the brakes to make sure they're getting full power. Link to comment Share on other sites More sharing options...
