Driving in M5 all the time
56 replies to this topic
#16 HondaHawkGT
HondaHawkGT
  • Member
  • 903 posts
  • Gender:Male
  • Drives:14 Silverado 1500 LT 5.3 DC
Posted 13 July 2015 - 03:27 AM
The only thing you're doing when you drive in M5 is locking out 6th gear and, thankfully, AFM. No harm at all.
Skip the Range and get the tune if you want a better solution. I bought the unit back in September that supposedly fixed all the issues. It caused my battery to almost completely drain dead in less than 48 hours, set off stabillitrack codes, and put my truck in a crippled limp mode state. After causing me to nearly lose my job twice due to truck issues, I'm finished with the Range unit.
Edited by HondaHawkGT, 13 July 2015 - 03:29 AM.
2014 Silverado LT Double Cab 5.3L 4x4
Cognito UCA's+Rancho Quicklift's + 3" Zone lift blocks
LT285/70R17 Toyo Open Country AT2 + 17x9 Level 8 MK6 +0 Offset
Gibson single swept-side exhaust
Black Bear Tune
#17 Front Runner
Front Runner
    "Si vis pacem, para bellum"
  • Member
  • 223 posts
  • Name:Brock Hardcastle
  • Gender:Male
  • Drives:2016 GMC Sierra Denali HD
Posted 13 July 2015 - 05:33 AM
Why is it such a big deal to not have it go into v4? I wish my denali would do it more. Mine is pretty seamless and I have to check the display to even see if it is in v4. I did notice it goes into v4 less when I went with the gm 22s vs the denali 20s, not sure what happened but still can get over 22+mpg on the hwy.
Does the 8sp make that much difference going from 4 to 8 and vice versa? It must be really bad for some of you guys to change it and risk your warranty
I've noticed the same thing with my 6.2 with GM 22's. It's not in V4 much.
2016 GMC Sierra 2500 HD
f50b73d9-e2eb-4c32-8b0a-b7b6de3fb090_zps
#18 mike5511
mike5511
    Retired
  • Member
  • 93 posts
  • Gender:Male
  • Drives:2015 GMC Sierra SLT
Posted 06 September 2015 - 03:19 PM
Second day of owning my 2015 Sierra. I've already discovered the manual trick and 5th gear. For those of you asking; running in V4 cause issues with the rings over time and excessive oil use. Get on google and check it out.  I would have it disabled, but that will void your warranty according to everybody I've talked to. When you first take off, just manual shift up to 5th and then it will down and up shift on it's own after that. Pretty simple.
#19 rdnckhntr94
rdnckhntr94
    K2 Section Moderator
  • Moderator
  • 5,977 posts
  • Name:CJ
  • Gender:Male
  • Drives:'14 Silverado CC short bed High Country 5.3L
Posted 06 September 2015 - 03:21 PM
Range AFM disabler will do it automatically in drive for about 200
HC emblem!
2" Top Gun Customz level kit, Bilstein 5100's all 4 corners, running board and air dam delete, Weathertech floormats front and rear, Diablosport intune i2 tuned, Volant CAI w/ Donaldson air filter, LT275/60R20 BFGoodrich All Terrain KO2's, bumper step LED's, Helwig Helper springs, Powerstop truck & tow front pads and rotors. New wheels and HID lows coming soon!
#20 mike5511
mike5511
    Retired
  • Member
  • 93 posts
  • Gender:Male
Posted 06 September 2015 - 03:26 PM
I'm new to this and the only thing I know about that is what I've read in this thread and it seems that has caused problems for some.....I'll investigate more, thanks!
#21 MikeNH
MikeNH
    Senior Enthusiast
  • Moderator
  • 8,858 posts
  • Name:Mike
  • Gender:Male
  • Drives:2015 Wrangler Rubicon
Posted 06 September 2015 - 04:53 PM
You don't have to manually shift it ever. I always selected M4/M5 the moment I put it in gear.
#22 Trucker Jeff
Trucker Jeff
  • Member
  • 184 posts
  • Gender:Male
Posted 06 September 2015 - 07:04 PM
I use M5 because engine is unable to keep RPM's or even speed especially  with A/C on, I will use Drive or M6 if able to use Cruise Control. With Magnaflow I only hear the funny 4V noise  when coasting or slowing down.
#23 cjd10
cjd10
  • Member
  • 62 posts
  • Name:cjd10
  • Gender:Male
  • Drives:2015 Sliverado LTZ Crew Cab
Posted 06 September 2015 - 08:21 PM
I found that running 89 octane helped my truck tremendously. 93 doesn't do anything for it but she seems to like 89. I used to stay in M5 in traffic most of the time but now I only use manual mode if it is stop and go crawling traffic
Charleston SC
2015ilverado LTZ Crew Cab
Deep Ocean Blue Metallic
Cocoa Dune Interior
#24 tnchevy
tnchevy
    Senior Enthusiast
  • Member
  • 1,095 posts
  • Gender:Male
  • Drives:2014 Chevrolet Silverado Z71
Posted 07 September 2015 - 05:37 AM
I have now ran two tanks of 89 octane and can not really feel any difference or gas mileage improvements so I am going back to 87 octane.
#25 glc
glc
  • Member
  • 474 posts
  • Name:Greg
  • Gender:Male
  • Drives:2014 Topaz blue Silverado 1500 LT double cab 5.3L 3.42 ratio
Posted 07 September 2015 - 12:19 PM
Half the miles I drive to work are rural and hilly. I got tired of truck constantly downshifting into 5th,so I started keeping it in M5. No difference in mpg either. Average around 20.5 in the summer on 91 octane. Winter is a different story. Anyway, I was constantly forgetting to upshift into 6th prior to getting on the turnpike, so I quit the M5, and just deal with the annoying constant downshifting. As I posted, it made no difference mpg wise, and just a few rpm higher. Wasn't hurting anything. Just a mental thing I guess. :)
Edited by glc, 07 September 2015 - 12:21 PM.
#26 mike5511
mike5511
    Retired
  • Member
  • 93 posts
  • Gender:Male
Posted 07 September 2015 - 01:18 PM
I'm thinking since the wife will steal it from me sometimes that this would be the way to go. I will have to remember to unplug it though because sometimes it will set for a few days. When the warranty is out, this truck will get a tune and be rid of the AFM!
Edited by mike5511, 07 September 2015 - 01:18 PM.
#27 chuckl1218
chuckl1218
    Senior Enthusiast
  • Member
  • 1,938 posts
  • Name:Chuck
  • Gender:Male
  • Drives:2016 Toyota Tundra Platinum CrewMax
Posted 07 September 2015 - 02:14 PM
My Range works great after having the software updated, but I learned the hard way to make sure I don't forget to unplug it if the truck is going to sit for a bit...4 days and battery was dead...
2016 03 20 16.12.12
2016 Toyota Tundra Platinum CrewMax (Silver Sky Metallic)
TRADED IN >> 2014 Silverado LTZ Double Cab Texas Edition ("Ruby")
#28 mike5511
mike5511
    Retired
  • Member
  • 93 posts
  • Gender:Male
Posted 17 September 2015 - 12:42 AM
Got my Range but haven't driven very much with it yet. It does work as advertised. Before that, I drove about 250 miles, in NW Arkansas which is hilly, all in M5 and got about 20 MPG. My speed was 60 - 70 MPH. I was pretty happy with that.  I'm thinking this 6th gear thing is going to be like 6th gear on my 08 HD....pretty much useless unless your speed is up around 80MPH. I'll figure it out as the miles accumulate.
#29 DAP56
DAP56
  • Member
  • 152 posts
  • Name:D
  • Gender:Male
  • Drives:2015 Silverado 1500 Custom Sport Plus LTZ-Z71
Posted 22 September 2015 - 12:59 AM
Is M5 the same as M7 for the 8 speed guys? I have the 6.2 with 22"s. 300 miles on the truck, I haven't seen V4 since drove it around the lot for the first time. When I need power, I put it into tow/haul mode and it flys. I will try M? Tomorrow....
#30 MikeNH
MikeNH
    Senior Enthusiast
  • Moderator
  • 8,858 posts
  • Name:Mike
  • Gender:Male
Posted 22 September 2015 - 07:13 AM
I'd assume so. M5 on the six speed is a very short overdrive. Driving in M mode doesn't hurt anything. Just start in 7 and work your way down as needed to fit your driving style/environment.
Reply to this topic
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
