- 0
Transmission Switch????
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 18 Members, 0 Anonymous, 1,864 Guests (See full list)
Question
gw1500se
I purchased a used 2000 GMC Sierra 1500 4X4 long bed (4.8L) and found that occasionally the shifter indicator was off by a notch (e.g. when in D the indicator showed N). Also the backup lights, when in reverse, would not come on but I could see them flash occasionally when moving the shifter to P. I thought this might mean a problem with the reverse switch (if there is one) on the tranny. I ignored it for a while and mention it now because it might lead to a diagnosis of my sudden serious problem. Also, on occasion when riding a speed, the doors would unlock, which again seems to imply a transmission indicator issue. Then the seemingly unrelated repair after which things went crazy. I turned the brake rotors and replaced the pads. Now the ABS light comes on, the brake warning light frequently flashes but not when actually braking and it will not shift out of 2nd. The fact that this followed the brake work is probably just coincidental since there were symptoms prior. Hopefully you have a some idea what this might be (control solinoid?). TIA.
7 answers to this question
