- 0
97 chevy fuel preasure
Similar Content
- 2 answers
- 1,388 views
- 8 replies
- 2,668 views
- 19 replies
- 1,891 views
- 17 replies
- 1,463 views
- 0 replies
- 1,690 views
Recently Browsing 0 members
245.8k
Total Topics2.6m
Who's Online 12 Members, 0 Anonymous, 934 Guests (See full list)
Question
Mikey Barnhizle
Is a very known topic that the Vortec spider injection system is prone to leak inside the intake and has problematic poppet valves I found exactly that being the problem of all my misfire codes and rough running issues replaced the spider injection with new current updated part which gives actual fuel injectors at the bottom of each tube my system now stores and holds pressure without hardly any leak down..
Now the real question I read everywhere that fuel pressure on vortex should be 6265 psi at Prime and full running condition or else vehicle will not start this is false! My vehicle now runs and starts at turn of key exactly the way it should and I am only producing 45 to 50 psi at prime and runninG..Fuel pump is one year old and the new fuel injection spider system is 3 days old so fuel pressure regulator is also knew as it comes part of the new injection system..When plugging off the vent back fuel line my pressure tags out the gauge so I know my fuel pump is capable of producing 90 psi or higher.
So why am I only producing 45 - 50 psi in my normal operation?..I have absolutely no leak down pressure and holds solid and firm at 45 psi for a long time after the key is turned off I also have 12 volts or more at the pump and confirmed all good grounds..Any takers on this one?..The truck runs and starts very well but I can still feel a slight miss not a complete smooth rhythm so I feel it may be due to the low fuel pressure..What does map sensor have anything to do with fuel pressure regulation seeing how the fuel regulator is inside the intake manifold on the spider injection system using internal engine vacuum to operate and MAP sensor reads these values?
2 answers to this question
