- 0
HVAC Problems
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 20 Members, 1 Anonymous, 1,158 Guests (See full list)
Question
jdnoble18
I am having horrible trouble with the HVAC.
90% of the time it runs cold on drivers side, hot on passengers side - on defrost - not adjustable no matter what setting is on the CCM
5% of the time the temp works on the drivers side but still is stuck on defrost
5% (if that) of the time it works as it should
You can turn off the CCM and turn it back on and feel the blend door reach the dash vents, then it seems like it cant hold that position and defaults to defrost.
I bought a temp actuator and put it in (on the drivers side position, under the dash) but nothing changed.
I bought a blend door actuator but looks harder to change than I feel comfortable with.
I've tried resetting the system several different ways (negative battery cable, pulling fuses, unplugging the CCM) then letting the system re-calibrate for 30 minutes before I start the vehicle. Nothing works.
All these things happened at one time, the problems did not accumulate over time.
I've read that a dealer might provide an update but I really don't want to go the dealer route unless I have to.
To me, it seems like all signs point to the CCM or (BCM Programming) being bad, since all problems started at the same time.
If one actuator does not work, does all the actuators go to their default?
Has anyone else had trouble like this before?
Any help is greatly appreciated, thanks!
3 answers to this question
