flyboyron Posted July 20, 2016 Share Posted July 20, 2016 I have 67,000 miles on my truck now, and I was washing my truck the other day and noticed that the fog light on the drivers side seems to be a little loose. The one on the passenger side is solid and doesn't move at all. So I talked to my mechanic and he had a look at it and said there are holes for some type of pins to go in and it seems that maybe one of the holes is just a little bigger than it should be causing the light to wiggle just a little and seem loose. The parts are all there and everything looks good so the light won't fall out. I was just wondering if the light rattles enough, will it cause the light filament to burn out? Any ideas how I can make the light feel solid again?....or should I just not worry about it? Link to comment Share on other sites More sharing options...
The Zip Posted July 21, 2016 Share Posted July 21, 2016 I don't like anything loose on my truck, especially if one of two is solid. Average driving should make it worse, but bumps will speed the process. Link to comment Share on other sites More sharing options...
Sierra Jon Posted July 22, 2016 Share Posted July 22, 2016 I would try to find and fill that gap with something. Maybe a plumbers putty or something like that that will hold up to the weather?? Or you could swap the halogens for LED bulbs - they are a little more durable to vibration. Sounds like a good excuse to upgrade though!! Sent from my Nexus 6 using Tapatalk Link to comment Share on other sites More sharing options...
LEDOAUTO Posted July 27, 2016 Share Posted July 27, 2016 Depends, if your fog ligh is led light already, it won't hurt. If it is halogen bulb, it will shorten its life span to drive on the rough road. Link to comment Share on other sites More sharing options...
wsk3 Posted July 27, 2016 Share Posted July 27, 2016 I have 67,000 miles on my truck now, and I was washing my truck the other day and noticed that the fog light on the drivers side seems to be a little loose. The one on the passenger side is solid and doesn't move at all. So I talked to my mechanic and he had a look at it and said there are holes for some type of pins to go in and it seems that maybe one of the holes is just a little bigger than it should be causing the light to wiggle just a little and seem loose. The parts are all there and everything looks good so the light won't fall out. I was just wondering if the light rattles enough, will it cause the light filament to burn out? Any ideas how I can make the light feel solid again?....or should I just not worry about it? Here's what I did after the dealer told me there is nothing they can do about it, on my 2012 Sierra. I took pieces of foam weatherstripping, the kind with adhesive on one side of it, and snugged it in between the lamp housing and the housing trim. Problem solved. GM mechanics have no creativity, if its not in their corporate manuals they have no clue. Instead of nuts and bolts, GM has decided that plastic clips and retainers build a vehicle faster and cheaper, maximizing profits. Link to comment Share on other sites More sharing options...
flyboyron Posted July 27, 2016 Author Share Posted July 27, 2016 Thanks wsk3. That sounds like a good idea. I have some in the garage so I will work on that first time I get a chance. Link to comment Share on other sites More sharing options...
